Gear Head's Solid Axle Turbo Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by Gear Head, Jan 13, 2015.
  1. Jan 10, 2016 at 4:54 PM
    #941
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
  2. Jan 10, 2016 at 5:31 PM
    #942
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    :drool:
    Gear Head[QUOTED][OP] likes this.
  3. Jan 10, 2016 at 6:02 PM
    #943
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Sounds like a pissed off tractor with a turbo lol
    ajohnson and Mothman like this.
  4. Jan 10, 2016 at 6:23 PM
    #944
    Gear Head
    Gear Head [OP] Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Lol it does chug a lug at lower rpms. If I can my afr dialed in it should help smooth it out some
    Mothman likes this.
  5. Jan 10, 2016 at 6:39 PM
    #945
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Hey! Looks like it is running. I was on a camping trip this weekend. If you have your bov after your maf it will make your truck want to load up between gears. It will go lean during spool up until you pop into open loop. A piggyback can help that, but it will always be there. Does it do it around 2k to 2.5k rpm?
  6. Jan 10, 2016 at 6:49 PM
    #946
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    How can I tell when it's in closed or open loop? And unfortunately my cluster doesn't have a tach so I can't really say if it's always doing it in a specific rpm range. It's going lean and wanting to die everytime I clutch in after being on the gas even if the bov doesn't open. In the vid when I'm rolling up to the stop sign you can hear me bump the gas to keep it alive
  7. Jan 10, 2016 at 6:59 PM
    #947
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Buy an Ultragauge, it'll give you tach read out and open and closed loop indicator amongst other features.
  8. Jan 10, 2016 at 7:02 PM
    #948
    MadTaco461
    CA
    Kinda stock
    I use a cheap Bluetooth obdii reader and torque app. It's really hard to trouble shoot over the forum. But stalling can be an air leak somewhere between the maf and the head. You have a boost gauge?
  9. Jan 10, 2016 at 7:04 PM
    #949
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Wouldn't an air leak anywhere result in an extreme rich condition though? Wideband is showing full lean. Yes, I have an AEM boost gauge
  10. Jan 10, 2016 at 7:13 PM
    #950
    MadTaco461
    CA
    Kinda stock
    It normal to go full lean after you release the gas. Called fuel cut. Well an air leak will go lean at idle and rich in boost
    Mothman likes this.
  11. Jan 10, 2016 at 7:18 PM
    #951
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Anything that can be done to keep it from stalling though? I'm pretty good at working all three pedals but that's going to get annoying in the rocks.
  12. Jan 10, 2016 at 7:52 PM
    #952
    MadTaco461
    CA
    Kinda stock
    Will it try to stall if you drive it very easy? If you can pull off the bov and drive around. That might be the fix. If that fixes it you need to plumb a hose to the front of the turbo.
    Mothman likes this.
  13. Jan 10, 2016 at 8:02 PM
    #953
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    It runs perfect driving it easy. It never wants to stall unless I'm clutching in. Doesn't matter if I was on the gas or off the gas before I clutch it.
    And fwiw I changed my fuel pressure regulator reference so that it only see's boost, no vacuum. Figured the vacuum might be cutting fuel pressure too much since it's showing 28 in/hg on deceleration
  14. Jan 10, 2016 at 9:11 PM
    #954
    MadTaco461
    CA
    Kinda stock
    Moving the fpr line shouldn't do too much at low end. -28inhg at decel the fuel injectors aren't even firing off. I might be a bit confused when you mean "clutching in" obdii reader and learning how to read the data is the best way to pin out a bug. If you change stuff around do little things one at a time so you don't get stuck in a downward hole. How close is your maf from the turbo?
  15. Jan 11, 2016 at 5:51 AM
    #955
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    My trucks 5 speed so when coming to a stop I'm pushing the clutch and brake. When the engine goes back to idle when I push the clutch in gauge is showing full lean and it will stall unless I feather the throttle.
    Maf is probably 8"-10" away from the turbo inlet. Just have a silicone elbow off the turbo and the maf is clamped to that
    Mothman likes this.
  16. Jan 11, 2016 at 8:19 AM
    #956
    MadTaco461
    CA
    Kinda stock
    Awesome thanks for the clarification. I'll still stand by that it is your bov throwing it off a bit. Whenever it releases any air the ecu is seeing hey I just ate this much air I should add fuel. O2 sensor is saying whoa way too much fuel. Ecu cuts back fuel. You can see it in your short term fuel trims. It will run lean causing it to want to stall. It will recover once you blirp the throttle because you need to let the fuel trim go back to normal.
    Mothman likes this.
  17. Jan 11, 2016 at 8:23 AM
    #957
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    This is what my boy adam was saying to me last night.. his words exactly.. "probably his sneezer messing with the ecu." @Gearhead
    MadTaco461[QUOTED] likes this.
  18. Jan 11, 2016 at 8:35 AM
    #958
    2000TRDTaco
    2000TRDTaco Well-Known Member
    Corey
    Angier, NC
    00 Prerunner
    @Gear Head I have a ultragauge II with suction cup mount that im looking to sell for $100
    Im down near Raleigh....could ship it to you
    Let me know
  19. Jan 11, 2016 at 8:40 AM
    #959
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Pretty sure you can buy new for that cost or cheaper.
    Gear Head[OP] likes this.
  20. Jan 11, 2016 at 9:45 AM
    #960
    Speedytech7
    Yeah I definitely only paid $70 for mine new, and it even comes with a mount that works perfect for 1st gens with the early steering wheel.
