Gear Hunting Defined???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2023Obar, Mar 9, 2023.
  1. Mar 9, 2023 at 7:56 AM
    2023Obar
    2023Obar [OP] Well-Known Member
    Central VA
    2023 TRD OR Lunar Rock
    * Tacoma TRD Lift Kit/Suspension Kit https://parts.toyota.com/p/Toyota__/Tacoma-TRD-Lift- Kit-Suspension-Kit/103339628/PT84K35221.html * UnderCover Tonneau https://undercoverinfo.com/undercover-flex * Spotter Mirror https://spottermirror.com/make/toyota/tacoma/ * Brite Box Anytime https://www.aspireautoaccessories.com/products/the-brite-box-toyota- tacoma-2016-2021?variant=39362278719552 * Bullet Point TacoBar https://www.bulletpointmountingsolutions.com/pages/toyota-tacoma- phone-mount-system-gen-3-2016 * Auxiliary Fuse Block Bracket https://overlandequipped.com/collections/fuse-block- bracket/products/copy-of-auxiliary-fuse-block-bracket-for-3rd-gen-toyota-tacoma-2016 * Blue Seas Fuse Block https://www.amazon.com/Blue-Sea-Systems-Blade- Block/dp/B001P6FTHC?&linkCode=sl1&tag=jeannet- 20&linkId=ea9025972a23e75ce7cde62b3f58ab70&language=en_US&ref_=as_li_ss_tl * Blue Seas Circuit Breaker https://www.amazon.com/Blue-Sea-Systems-Circuit- Breakers/dp/B000MMFJJI?&linkCode=sl1&tag=jeannet- 20&linkId=4470c99f70290fc3a632e51a3c69bf4d&language=en_US&ref_=as_li_ss_tl * Car Hard Wire Charger, 12V to 5V Dual USB Female Port Charging Cable https://www.amazon.com/dp/B07H6W1BZG?psc=1&ref=ppx_yo2ov_dt_b_product_details * Body Armor 4x4 HiLine Front Bumper https://bodyarmor4x4.com/products/tc-19339-front- winch-bumper * Rough Country Winch https://www.roughcountry.com/winches-and-accessories.html * Rough Country 20" Light Bar https://www.roughcountry.com/20-inch-led-light-bar- 70920bl.html
    I am new to the Tacoma family and going to pose, what I am sure will be the first, of my silly questions.
    My wife has 2005 4 Runner and I know that is a bigger engine (4.7L v8), but the throttle response is much better than my 23' TRD OR 3.5L v6. The 4 Runner has much more direct reaction to pedal interaction. I am in Central VA and constantly on hilly roads. Whether ECT engaged or not, when Cruise Control is engaged, the Taco seems to drop in and out between 6th & 4th gears regularly, sometimes on longer, steeper runs I may even hit 3rd gear. Is this the "Gear Hunting" everyone speaks about. That does not happen as egregiously in the 4 Runner. Thanks in advance.
  2. Mar 9, 2023 at 7:58 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
  3. Mar 9, 2023 at 7:59 AM
    Shellshock
    Iowa
  4. Mar 9, 2023 at 8:08 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Welcome to owning a 3rd gen! :laugh:
    I too live in a hilly/mountainous region. I've found if before a hill to tip into the throttle a little harder and it'll downshift so you won't lose speed rather than it doing it mid hill and you lose momentum. Sucks, but you get used to it.
    2023Obar[OP] likes this.
  5. Mar 9, 2023 at 8:15 AM
    betrayus
    betrayus Milk steak connoisseur
    Denver, CO
    2021 SR5 DCSB 4x4 AT (MGM)
    Stock
    You'll get used to it. If it still bugs ya after a while, get a tune put on it.
    2023Obar[OP] and Kolache007 like this.
  6. Mar 9, 2023 at 8:18 AM
    Tacoma Rant
    Tacoma Rant I can’t be good all the time.
    Wisconsin
    2023 Tacoma TRD Sport Electric lime
    According to the YouTuber Car Care Nut, it’s all about emissions. Toyota in their infinite wisdom believes that this set up will save fuel and Cut down on emissions.
    I’m actually thinking about getting a pedal commander, my truck is brand new and I don’t want to put a tune on it yet.
    2023Obar[OP] and Road_Warrior like this.
  7. Mar 9, 2023 at 8:21 AM
    Brian 0blivi0n
    Brian 0blivi0n Well-Known Member
    Wisconsin
    2018 TRD OR
    Try "S" Mode? Tune? Part out?
    I drive with ECT and "S" mode always on and it pretty much alleviates most of the Tacoma transmission quirks for me.
    TacoTime55 and 2023Obar[OP] like this.
  8. Mar 9, 2023 at 8:24 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    It’s because in a test they want the truck to go into 6th gear asap. On a flat smooth surface it doesn’t take much power to make the truck go 60mph. Having the rpm’s so low decreases emissions output while in a test setting. In the real world with hills and varying terrain it doesn’t work quite as well. When you start adding things like armor and bigger tires it only gets worse.
    Canadian Caber and 2023Obar[OP] like this.
  9. Mar 9, 2023 at 8:24 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Yeah, that’s what you’re feeling. I dealt with it for a while then eventually had enough and got the KDMax tune and that made the truck drive like a whole new vehicle.
    PapaRee and 2023Obar[OP] like this.
  10. Mar 9, 2023 at 8:27 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    it's just the way it's designed
  11. Mar 9, 2023 at 8:32 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Don't waste your money. All a pedal commander does is press the pedal a little harder than you do. That's it. It's a digital brick tied to your foot. If you want to change the behavior of the truck, a tune is the only way to do so. Well, aside from changing the behavior of your left foot, that is.
  12. Mar 9, 2023 at 8:33 AM
    arthur106
    arthur106 Well-Known Member
    Jacob
    Houston
    Black '10 SR5 4WD 5MT
    I’m not an expert but drawing on some knowledge in the deepest recesses of my mind from my engineering days.. emissions and economy are not the same thing. Sure, economy is super important and what most owners care about, but you also have to worry about NOx, SOx, and hydrocarbon (from incomplete combustion) emissions just to name a few. There’s so much going on with the engine that it’s quite incredible it can all be controlled by a single pedal input (throttle position, fuel ratio, exhaust gas recirculating, spark timing, valve timing, etc.)
    The throttle by wire system handles all this. It does a great job of doing what it’s designed for; unfortunately, the EPA forced Toyota engineers to sacrifice drivability for emissions/economy. ECU tunes are a great way of overcoming this, however.
    Edit: Pedal Commander won’t solve your root problem. It just makes the car think you’ve pushed the pedal down further than you have, giving people the illusion that the car’s behavior has changed.
    Canadian Caber, 2023Obar[OP] and Chew like this.
  13. Mar 9, 2023 at 8:38 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    someone gets it!
    Many think big bad Toyota got bored and mean one day, and designed the truck this way to torment it's owners. And before someone compares it to another model and/or brand, keep in mind old generations still in production won't get the re$ources for an engine redesign mid model, and an MFG's overall numbers are scaled, so high volume vehicles greatly affect their overall number.
  14. Mar 9, 2023 at 9:07 AM
    arthur106
    Jacob
    Houston
    Yup, we’re running super old engine designs, except for a few minor changes and although they are bullet proof, tried and true, they just weren’t built to produce the results the EPA demands. We have amazing trucks, they’re just neutered.
  15. Mar 9, 2023 at 10:22 AM
    Ole No. 1
    Ole No. 1 Well-Known Member
    2023 TRD OR DCSB 4WD
    I just got a 2023 DCSB OR a couple months ago and feel your pain. Side streets and traffic up to 60-65MPH or so, the AT performs fine. No real complaints other than the engine doesn’t rev out very quickly. But get over 65 and into any inclines or hills and it is upshift, downshift, upshift, downshift. And with cruise control it is obnoxious. And the incline doesn’t have to be much to make it do it. I’ve started putting my foot into the go pedal more to get speed before inclines but it still shouldn't require it.
    My wife’s 2020 Jeep Grand Cherokee has the Pentastar 3.6L V6 with an 8 speed AT and it doesn’t have to downshift going over the same terrain at the same speeds and hardly requires any more throttle to maintain speed. And it only has 295HP w/ 260lb-ft of torque which is very comparable to the Tacoma. But they drive very, very different. Granted it is a truck compared to an SUV but still… the 3.5L in the Tacoma just doesn’t have the tuning “ooomph” to make it go.
    And we actually had a 2017 Camry with the 3.5L V6 and the 6 speed AT before the Tacoma. So I know what the engine and trans are capable of. In the Camry that engine would rev quick and do 85+ without ever needing to downshift on slight hills or inclines to maintain speed.
    As others have said, the Tacoma has just been neutered, for whatever reason, and as soon as I’ve got the time I’m getting it Overland Tailer tuned.
  16. Mar 9, 2023 at 10:45 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I think for one thing the 4runner has a 5 speed auto, and less overdrive than the 6 speed tacoma. I can tell you my 3.5 sr5 feels very similar up to 4th gear as my 2001 4.7 tundra to 4th.
    Chew and 2023Obar[OP] like this.
  17. Mar 9, 2023 at 11:39 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Pedal Commander could actually make your problems seem worse by increasing the throttle position sensitivity thus, making the demand for power, and rpms... causing more or premature downshifting. get the KDMAX Pro9 tune. ski
    PapaRee, 2023Obar[OP] and Ballz like this.
  18. Mar 9, 2023 at 12:21 PM
    2023Obar
    Central VA
    Yep I did that today rolling around and it was definitely better. But if I wanted to do the shifting in town, I would have bought the S/T. I may just part it out! :bananadance:
    davidstacoma likes this.
  19. Mar 9, 2023 at 12:23 PM
    2023Obar
    Central VA
    Yep! All of this. Off topic... great profile pic.
    Chew[QUOTED] likes this.
  20. Mar 9, 2023 at 12:24 PM
    2023Obar
    Central VA
    Just what I needed... more overwatch from another federal department of our government.
