Gear Hunting Defined???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2023Obar, Mar 9, 2023.
  1. Mar 9, 2023 at 12:25 PM
    2023Obar
    2023Obar [OP] Well-Known Member
    Central VA
    2023 TRD OR Lunar Rock
    * Tacoma TRD Lift Kit/Suspension Kit https://parts.toyota.com/p/Toyota__/Tacoma-TRD-Lift- Kit-Suspension-Kit/103339628/PT84K35221.html * UnderCover Tonneau https://undercoverinfo.com/undercover-flex * Spotter Mirror https://spottermirror.com/make/toyota/tacoma/ * Brite Box Anytime https://www.aspireautoaccessories.com/products/the-brite-box-toyota- tacoma-2016-2021?variant=39362278719552 * Bullet Point TacoBar https://www.bulletpointmountingsolutions.com/pages/toyota-tacoma- phone-mount-system-gen-3-2016 * Auxiliary Fuse Block Bracket https://overlandequipped.com/collections/fuse-block- bracket/products/copy-of-auxiliary-fuse-block-bracket-for-3rd-gen-toyota-tacoma-2016 * Blue Seas Fuse Block https://www.amazon.com/Blue-Sea-Systems-Blade- Block/dp/B001P6FTHC?&linkCode=sl1&tag=jeannet- 20&linkId=ea9025972a23e75ce7cde62b3f58ab70&language=en_US&ref_=as_li_ss_tl * Blue Seas Circuit Breaker https://www.amazon.com/Blue-Sea-Systems-Circuit- Breakers/dp/B000MMFJJI?&linkCode=sl1&tag=jeannet- 20&linkId=4470c99f70290fc3a632e51a3c69bf4d&language=en_US&ref_=as_li_ss_tl * Car Hard Wire Charger, 12V to 5V Dual USB Female Port Charging Cable https://www.amazon.com/dp/B07H6W1BZG?psc=1&ref=ppx_yo2ov_dt_b_product_details * Body Armor 4x4 HiLine Front Bumper https://bodyarmor4x4.com/products/tc-19339-front- winch-bumper * Rough Country Winch https://www.roughcountry.com/winches-and-accessories.html * Rough Country 20" Light Bar https://www.roughcountry.com/20-inch-led-light-bar- 70920bl.html
    My plan as well. Hopefully squeeze it into the budget for next month. OTT, see you soon.
  2. Mar 9, 2023 at 1:45 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Thanks, There’s a couple guns threads in the hunting sub forum here.
    2023Obar[QUOTED][OP] likes this.
  3. Mar 9, 2023 at 4:42 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Gear hunting is a term used my owners of automatic transmissions that should have bought a CVT instead.
    :crapstorm:
    2023Obar[OP] and zoo truck like this.
  4. Mar 9, 2023 at 4:44 PM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Independently, the engine is excellent, and transmission is bullet proof. The problem that many observe is that the engine design wants you to rev higher to make power while the tranny’s shift programming wants you to slow the fun down to save a buck or two in gas.
    If you tow, drive it like it’s the final lap at Daytona, or roll up & down a lot hills on your way to work, it may not be the truck for you and we’ll probably hear your complaints on this forum. Fortunately I live where it’s flat and get 20mpg so all good here.
  5. Mar 9, 2023 at 5:20 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Regear
    2023Obar[OP] likes this.
  6. Mar 9, 2023 at 10:49 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Try deleting learned values. I did on my 22 in November after buying mine in October. For the first 500 miles after deleting I would every 30 or 40 miles floor it and let the trans do it job. No gear hunting no nothing now. Shifts like an old GM th350 now.
  7. Mar 9, 2023 at 11:11 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Comparing apples to oranges there, on the Jeep... 8 speed auto, and 6 speed auto, with a passenger (comfort) vehicle, and "truck". having the 8 speeds will allow it to be in the correct gear, for just about most situations. think pedal bike with multiple gears, grab the one you need for the riding at hand. and also guessing the trans logic, is a ton smoother in the 8 vs the 6, to give you a more "seamless" less shifting feeling but, I guarantee you... it is shifting a bunch.
    Also... the camry is close to a 1000lbs lighter than the tacoma so... if we could take 1000 lbs off the tacoma, it would feel peppier, and not shift as much, lugging around that added weight. your results, may vary. Ski
  8. Mar 9, 2023 at 11:55 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Put it in ECT and S4 around town and you’re done. No more manual shifting required unless you’re on a flat road with higher speeds and then S5.
    Ain’t no thang.
  9. Mar 9, 2023 at 11:59 PM
    erok81
    erok81 Well-Known Member
    Imposter
    You haven’t owned a pedal commander have you?
  10. Mar 11, 2023 at 4:39 PM
    Domeimazn
    Domeimazn Well-Known Member
    Henro
    2020 tacoma pro
    Ect kills my issues
    2023Obar[OP] and Brian 0blivi0n like this.
  11. Mar 11, 2023 at 7:37 PM
    Gord0
    Gord0 Well-Known Member
    Ok for starters this is not a “truck” it’s a confused Camry at best.
    I was ready to get rid of my ‘21 after 6 months, threw an OTT tune at it but that barely helped. Then almost by accident, I ended up with a set of 255/75/17’s threw them on and just like that it’s a new ride. Gear hunting is 95% gone, power band is much more accessible. As others have said the motor is good, the power is there. In my opinion it’s a gearing issue.
  12. Mar 11, 2023 at 10:47 PM
    TuesdayTaco76
    TuesdayTaco76 Well-Known Member
    Moochacho
    California… thanks for leaving
    23 Tacoma TRD OR SB CB (chrome bumper✊)
    Still all in my head… but I’m keeping the chrome bumper!
    Throwing a lot of money and effort in that “Camry” of yours.
    Chew likes this.
  13. Mar 11, 2023 at 10:53 PM
    Gord0
    Yep and it doesn’t even drive as well as a real Camry.
    * for the record my wife bought it and gave up on it after two months, she promptly commandeered my GX.
  14. Mar 11, 2023 at 11:40 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    The ECU has a component of AI that can learn how you drive. Also the other component is what Toyota calls "Force Value" Its when the the transmission and engine have a meeting and try and anticipate what your going to do next with the "input" aka gas peddle. Sometimes resulting in confusion leading to a short hesitation. The transmission will also sense when you are going down a steep hill and down shift for you whether you like it or not.. Deviate from stock with bigger tires and heavy add-on's the grief increases.
    I have learned what to expect and intervene with S-Mode and or with ECT when I need to take over from the computer to take back control. A tune will help do this as well.
  15. Mar 12, 2023 at 12:03 AM
    #35
    Canadian Caber
    Les
    B.C. Canada, eh
    Could not agree more with you two. At the end of the day pick your poison. All to lower emissions whether you like it or not. You can pick one.
    1. Engine stop start.
    2. AFM (active fuel management), aka cylinder deactivation.
    3. Toyota’s famous “Taco Tune” to lower emissions on Tacoma’s.
    4. Turbocharged, smaller displacement engines.
    What’s it going to be? Not including Hybrids or EV’s.
    2023Obar[OP] and Chew[QUOTED] like this.
  16. Mar 12, 2023 at 8:15 AM
    #36
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    S4 helps, but I find ECT useless around town. 2800-2900 RPM in 3rd driving 35mph is just not acceptable.
  17. Mar 12, 2023 at 9:03 AM
    #37
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2021 4runner "Luna" 2023 Solar Octane MT "Solaris"
    [Insert manual transmission comment here]
  18. Mar 12, 2023 at 9:24 AM
    #38
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Toyota needs to take a lesson from Nissan with the new frontier drivetrain. Nissan actually did a good job with it.
  19. Mar 12, 2023 at 11:26 AM
    #39
    2023Obar
    Central VA
    Just trying to learn some of the terminology. Not really a complaint, and not really a complainer, but please, keep on making judgements based on a random question on a forum. :hattip:
  20. Mar 12, 2023 at 1:23 PM
    #40
    Lunar Squirrel
    Sorry if I came off a little surly. I drove a 4.0/5spd combo prior and agree there is a noticeable difference.
