Gear hunting? What am I missing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gerberdude, Feb 9, 2023.
  1. Feb 9, 2023 at 1:10 PM
    #41
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You are not missing anything. This “complaint” is way overblown on here.
    It’s a transmission with 2 overdrive gears. Even the manual says to use s4 or s5 in hilly/mountainous/city driving. Most people chose to ignore that page and post a thread on here complaining how terrible “transmission logic” is.
    I drive a manual and even I know about the “S” mode in the Tacomas.
  2. Feb 9, 2023 at 1:11 PM
    #42
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    It is most noticeable at freeway speeds on steeper hills (I'm in CA - driving between San Diego and Temecula on I-15 will do it to ya!). I usually keep the speed down around 60 and it doesn't gear hunt. ONce I get up to 65 it starts to do it. It is just annoying.
    I don't get it at all on surface streets or flat roads or slight inclines at lower speeds.
  3. Feb 9, 2023 at 1:12 PM
    #43
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Sir, it’s a high revving v6. Makes peak power at 4K+ RPMs. Your transmission downshifted like it was designed to do…
    D. Lengua, 71tattooguy and supmet like this.
  4. Feb 9, 2023 at 1:13 PM
    #44
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Lol. I'm well aware of what is posted on TacomaWorld. The problem is NONE of it is consistent. Read my post again...everybody complains about something different. I want to see how one actually drives as I don't trust the complaints of many others.
  5. Feb 9, 2023 at 1:14 PM
    #45
    BattleKat
    San Diego
    To be honest I never thought of that. I use S mode going down steep hills to help out not riding the brakes. Had not thought of it on uphills at higher speeds. I will give it a try next time I think it will gear hunt. (For the record I don't find it a big problem but I do notice it)
    71tattooguy and Junkhead[QUOTED] like this.
  6. Feb 9, 2023 at 1:18 PM
    #46
    BattleKat
    San Diego
    I'm not complaining, I'm making an observation that I hadn't experienced in 15K miles of driving it. And I wasn't at 4k, I was nearly at 6k and couldn't get it to come down. I've never redlined a vehicle before and I felt like I didn't have control over it. Like I said it wasn't even floored.
    Junkhead[QUOTED] likes this.
  7. Feb 9, 2023 at 1:28 PM
    #47
    BLtheP
    Plano, TX
    Freaky? Why? Anything below redline is the safe zone. Your computer is too smart to put you outside of the safe zone.
    Edit: did not see the comment above mine when I posted this one.
  8. Feb 9, 2023 at 1:29 PM
    #48
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Give it time, the transmission will learn your habits. It’s a actually a very intelligent transmission.
  9. Feb 9, 2023 at 1:30 PM
    #49
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    You could spent a few days to read some of the old threads to get familiar with basics of at tacoma ecu/tcu before painting with a broad brush..
  10. Feb 9, 2023 at 1:30 PM
    #50
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I knew it! Just another "you need a tune" commercial.
    MadKatt, ToyoTaco25, Tstege83 and 3 others like this.
  11. Feb 9, 2023 at 4:38 PM
    #51
    Kolohe07
    Kolohe07 Well-Known Member
    David
    Haiku , Maui, Hi
    2022 Access cab Sport 4x4 Celestial Silver
    A Sprint booster or a Pedal Commander should fix yer Gordon Lightfoot.
    J Williams likes this.
  12. Feb 9, 2023 at 5:48 PM
    #52
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    put it with ect switch on, and put it in S and then in 6...makes it hunt less. several tunes available too
    BattleKat likes this.
  13. Feb 9, 2023 at 7:55 PM
    #53
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    22 here also with 4K miles. No hunting. Need to pass push skinny pedal and it downshifts like it should. Let off pedal and it up shifts back.
    MadKatt, Kolohe07 and Gerberdude[OP] like this.
  14. Feb 9, 2023 at 9:08 PM
    #54
    Tacoma Trailhead
    Tacoma Trailhead Well-Known Member
    2023 Magnetic Gray Trail Edition
  15. Feb 9, 2023 at 9:45 PM
    #55
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I'm with the OP on this one - got zero complaints about my 2021 - drives like a dream compared to what I came from, wouldn't change a thing.
    eurowner and Gerberdude[OP] like this.
  16. Feb 9, 2023 at 9:55 PM
    #56
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I have the KD Max tune but I still put the truck in S5. I may loose a smidgen of gas I reckon? LOL.
    71tattooguy likes this.
  17. Feb 10, 2023 at 6:55 AM
    #57
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've had a 2020 sr5 v6 auto for the last 3 years. The transmission shifted funky for the first 1200-1500 miles till it learned my driving habits, and general road conditions I traveled. After that it seemed the engine even made a lot more power and the transmission worked spot on. To this day the truck has been perfect...no complaints. From what I've heard not all tacomas with an auto work the same. You can get one like myself, or others have, or you can get one that performs like a pos as a buddy had.
    Kolohe07 likes this.
  18. Feb 10, 2023 at 7:18 AM
    #58
    2021SR5V64WD
    The trucks are the same coming off the line.
    The only variable in the equation is the driver and their driving habits.
  19. Feb 10, 2023 at 7:19 AM
    #59
    Gerberdude
    Gerberdude [OP] Well-Known Member
    Alex
    '22 SR5 DCLB
    Among other things at work I provide the IT support. I like to tell people that the problem is between the chair and the keyboard. Then I sit quietly and wait for them to figure that out.
    rybern likes this.
  20. Feb 10, 2023 at 7:21 AM
    #60
    2021SR5V64WD
    Ha ha. Having spent 30+ years in the I.T. industry I'm surprised that is still an issue, then again, not really.
