Gear Indicator Light
Discussion in 'Technical Chat' started by cavilry, Nov 8, 2010.
  1. Nov 8, 2010 at 8:05 AM
    cavilry
    cavilry [OP] Well-Known Member
    San Jose, CA
    06 Tacoma TRD 4x4 LT
    Total Chaos Long Travel Kit, King Shocks, Deaver Leafs
    The gear indicator lights on my 2006 v-6 AT have been acting up. 4 will not longer display (not that it matters too much) but when I drive in the rain, R lights up (while driving in D). It will go away once it dries out so I am guessing something is just shorting. Any ideas what?
  2. Nov 8, 2010 at 8:10 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    The gear indicator is connected to a plug on the transmission. I would crawl under your truck. pull each plug connected to the transmission. Dry them out good with compressed air. After you plug them back in coat them with some RTV silicone to keep them dry.
  3. Nov 8, 2010 at 8:11 AM
    98tacoma27
    Ben
    Not Beech Creek
    Could be or a loose connection somewhere that is allowing water in.
  4. Nov 8, 2010 at 9:36 AM
    cavilry
    San Jose, CA
    Thanks guys
    Very much appreciated! :)
  5. Feb 2, 2015 at 5:45 AM
    scamer
    scamer New Member
    2007 TRD Sport
    2007 Tacoma: This issue with the gear indicator lights on the dash seem to be directly linked to the gear shifter (the stick) movement, because if I wiggle it, I can see the "D" flashing and eventually with a bit of perseverance, I can get it to stay lit.
    Question: Is there any switch in the gear shifter (in the console) that may not make contact properly? (It is extremely cold these days - can it be related to this?)
