Gear oil dripping from inner CV boot
Discussion in '1st Gen. Tacomas (1995-2004)' started by jeg0005, Jun 17, 2019.
  1. Jun 17, 2019 at 8:51 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    It is probably just old grease in there with god knows how many miles (probably from the factory). I know my grease gun leaks out some liquified goop after sitting for a while. More than likely, you had some of that liquified grease in there and once you lifted the truck, the worn out CV clamp gave that liquid goop an easy exit.
    jeg0005[QUOTED][OP] likes this.
  2. Jun 17, 2019 at 8:52 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Does it smell like grease? Or does it smell sour like diff oil?
  3. Jun 17, 2019 at 8:52 PM
    jeg0005
    jeg0005 [OP] Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    Ok now I see what you're saying. I didn't see this picture before.
  4. Jun 17, 2019 at 8:52 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I tend to want to add things after the fact :) that's my bad haha
  5. Jun 17, 2019 at 8:53 PM
    jeg0005
    Jon
    BHM, AL
    It kinda had a gear oil smell, but I can't commit to that scent not already being on me since we were messing with my brother in law's FJ60 front diff before. And I saw it actively dripping, which I don't think cool grease would do.
  6. Jun 17, 2019 at 8:54 PM
    jeg0005
    Jon
    BHM, AL
    @ThunderOne I'm going to try and trace it to see if it's coming from that area and just dripping down the CV.
  7. Jun 17, 2019 at 8:55 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I think it would be pretty tough for diff oil to run down your axle onto your boot, but I guess crazier things have happened
    turbodb likes this.
  8. Jun 17, 2019 at 8:56 PM
    jeg0005
    Jon
    BHM, AL
    I hope this is the case. I'll update.
    ThunderOne[QUOTED] likes this.
  9. Jun 17, 2019 at 9:40 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    As someone who just replaced both axle seals, I don’t see how it could be leaking from the axle seal and going down the boot of your CV.
    One side on my truck was leaking on the skid plate and then running off there to the ground. I replaced both sides because I was changing one CV and both ball joints so I was in there to begin with. I think it’s old nasty grease leaking from the boot that may have had some water get in and mix with the grease. My 883s did the same thing after they were installed.
    ThunderOne and jeg0005[OP] like this.
  10. Jun 17, 2019 at 10:18 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    If it ends up being your CV boot leaking, and not your diff... here's a write-up with photos on replacing the boots, including part numbers, tools, etc. Reasonably easy job once you have the parts and tools, just a little time consuming.
    How-to: Rebooting a Tacoma CV Axle
  11. Jun 17, 2019 at 10:22 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I’m gonna say it’s safe to drive if that hasn’t been said already.
    I’ve been doing so for 3 years :anonymous:
    turbodb and ffirg like this.
  12. Jun 17, 2019 at 10:24 PM
    ffirg
    mike
    Anchorage, Alaska
    Yeah for sure. I had been leaking some for a while. When I finally changed the seal I also did a drain and fill of the diff and only got slightly less than half a quart out. I believe I put in just over 1qt when I filled it...
    turbodb likes this.
  13. Jun 17, 2019 at 10:25 PM
    jeg0005
    Jon
    BHM, AL
    I guess it just worried me that it looked like gear oil and not grease. It also happened all of a sudden and it seemed like a lot was leaking out in such a short amount of time
  14. Jun 17, 2019 at 10:27 PM
    ffirg
    mike
    Anchorage, Alaska
    Have you checked your diff breather to make sure it isn’t clogged? I wonder if it heated up enough in there that it blew off pressure through one of your seals instead of the diff. I guess I could see that happening but it still seems difficult to see it get on the boot and drip down the shaft like that.
  15. Jun 17, 2019 at 10:27 PM
    #35
    JKO1998
    Utah
    I should have clarified,
    If it’s just a tore boot I’d say just get to it when you can.
    Sooners definitely better obviously.
    Leaking diff I’d make a priority
  16. Jun 18, 2019 at 5:12 AM
    #36
    SouthernYoder
    SouthernYoder If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    Mine did the exact same thing big dog. I went and got new remanufactured CVS from Toyota here locally and kept my originals for spares just in case. My original OEM had 120k on them so I just swapped them. When my clamp on my boots did that, I wheeled it lightly for a couple weeks and they was still fine. That’s just part of lifting your rig man. Also, I don’t have a diff drop nor armor or a winch on right now and I’ve rode those 883 for 2 years now and they have settled decent but rides like a wagon; my cv angles aren’t bad unless I droop it a little The taco is my garage queen and I daily a XJ with 4.5 lift and 33’s.
    jeg0005[OP] likes this.
  17. Jun 18, 2019 at 9:38 AM
    #37
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Just to reiterate, you do NOT need to reboot the whole axle. You just have a worn out clamp. All you need to do is replace the clamp. There is no need to reboot your CVs at this time, not until they tear will you need to worry about that. And I have driven lots of miles on a blown boot before, it's not a huge deal until you get mud or dirt inside it.
    If you diff was leaking, it would not be leaking where it is.
    jeg0005[OP] and SouthernYoder like this.
  18. Jun 18, 2019 at 9:41 AM
    #38
    SouthernYoder
    Knoxvegas, TN
    ^^^^ All of this.
  19. Jun 18, 2019 at 9:52 AM
    #39
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I dunno, that kinda depends on the condition of the grease, no?
    If the grease in there is runny and contaminated with water (or just generally really old), wouldn't be a bad idea to rebuild/replace them... But definitely not as high a priority as if the boot were torn.
  20. Jun 18, 2019 at 9:56 AM
    #40
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    well if he really wanted to not have to take the whole thing out, he could remove both clamps, slide the fat side of the boot forward, scoop out the old grease and inject some new grease in there. Or at least inspect it and see if it needs all that. Then pop the boot back on and re-clamp it
    jeg0005[OP] and jbrandt[QUOTED] like this.
