Gear Oil for Front Diff on a free-wheeling hubs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JaCkaL829, Feb 20, 2013.
  1. Feb 20, 2013 at 5:59 PM
    JaCkaL829
    JaCkaL829 [OP] Member
    Hello,
    I just picked up a 96 Tacoma, I wasn't sure how the 4wd system works, but after reading the owner's manual last night, I realized my Tacoma has the free-wheeling hubs, not the Automatic Differential disconnect (ADD). With that said my owner's manual recommends 80W-90 for my front differential for NON-ADD for a change, along with 80W-90 for the rear.
    Now my Haynes book, has the same oil viscosity recommendation for the rear, but for the front it says 75W-90. Just wondering which one is correct? I just bough a gallon of Valvoline dino 80W-90 and just want to make sure it'll be OK for the both differentials. I plan on using Redline MT-90 for my manual transmission fluid, and probably dino Valvoline 75W-90 for the transfer case. The cost of gear oil isn't cheap lol.
    I just wanted to double check the correct gear oil viscosity for the front. The dino Valvoline 80W-90 does say it works for hypoid. Not sure if I'm overconcerned and splitting hairs with these oils.
    Thanks in advance!
  2. Feb 20, 2013 at 6:04 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    it really dont make a difference
    just avoid royal purple
  3. Feb 20, 2013 at 6:08 PM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Why's that?
  4. Feb 20, 2013 at 6:10 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    I have used Royal Purple for years and have had no trouble at all
  5. Feb 20, 2013 at 6:10 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    found to have the absolute worst wear of all the gear oils tested, Lucas is what ecgs reccomends
  6. Feb 20, 2013 at 6:12 PM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    good to know too late for me at this point 115K so I guess ill just keep using it at this point
    where can you see wear results?
  7. Feb 20, 2013 at 6:14 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    Don't use royal purple ever under any circumstance!!! Likely the worst gear oil ever made. 15k diffs with royal purple look like they have 200k on them. It thins out and provides no gear cushioning and does not control heat.
    he reccomends 85-140 lucas.
    never too late to change also make sure the trans has gl-4 not gl-5, gl-5 has been known to eat brass
  8. Feb 20, 2013 at 6:18 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    I just changed all those fluids today. I went with amsoil. There is a dealer here on TW that gives a great discount, making it the same, if not less then most of the stuff you get at the autopart store, minus their own brand.
    Went with GL5 75w-90 for the diffs, and GL4 75w-90 for the trans and transfer case.
  9. Feb 20, 2013 at 6:21 PM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    Ok I'll change it soon then
  10. Feb 20, 2013 at 6:47 PM
    JaCkaL829
    Is the GL-5 oil OK for my transfer case? I already picked up Redline MT-90 which is GL-4 for the manual transmission fluid.
  11. Feb 20, 2013 at 7:07 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    I run Amsoil everything (yes, even coolant) and have a combined 315,000 on my two Tacomas with no lubricity issues.
  12. Feb 20, 2013 at 10:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The MT90 is a great choice for the 5-speed. And yes, GL-5 is OK in the t-case, its only the manual transmission where you don't want to use GL-5.
