Gear oil in motor oil container.
Discussion in 'Technical Chat' started by replica9000, Sep 16, 2014.
  1. Sep 16, 2014 at 7:05 AM
    replica9000
    replica9000 [OP] Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I have some Redline gear oil. The bottles they come in don't have any measurements on them, and the opening is too small to screw a pump on to. I've just done an oil change, and saved one of the bottles. I left it upside down overnight to drain any motor oil that was left in it. Looks like it's just a film that's left over from the motor oil. I wouldn't think there was enough motor oil left to affect anything. I should be okay to transfer the gear oil into the motor oil container so I can pump it into the gearbox/tcase/diffs right?
  2. Sep 16, 2014 at 7:16 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I used duct tape and wrapped the bottle until I could screw the pump cap on.
  3. Sep 16, 2014 at 7:21 AM
    replica9000
    2019 T4R ORP
    Sounds like more chance for a mess.
  4. Sep 16, 2014 at 11:29 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    It wasn't too bad. I used a bottle pump from autozone. The bottle can stand up on the ground and there's enough hose to go to the tranny. I only had a few drips after pulling the hose.
  5. Sep 16, 2014 at 1:32 PM
    replica9000
    2019 T4R ORP
    I ended up using the old oil container. :D
