Gear oil - maintenance - a couple questions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steveo27, Dec 22, 2014.
  1. Dec 22, 2014 at 9:07 PM
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Im getting ready to do the next round of routine maintenance to my truck - changing the gear oil in the front and rear differential, the transfer case, and the manual transmission.
    I found all the little DIY's and stickies on here, they all have helped me out a lot with information, but I still have a few questions.
    First off, here is the list of everything I came up with -
    - First question
    Does anyone have the part numbers to all the fill and drain plugs. I want to order/replace each one as more of a precaution (possible damaged plugs) than anything else. Ive seen some of te horror stories people have posted about stripped/damaged plugs. I am the second owner of my truck and I dont exactly know 100% what the previous owner/dealership did to it. Id just feel better having new, non stripped plugs to reinstall.
    - Second question
    Does anyone have the part numbers for both of the crush washers on transmission?
    - Third question
    I've typically had pretty good luck running Mobil 1 synthetic gear oil in the past in my VWs. I know the Mobil 70w-90 is a GL5 gear oil, which should be fine for the front and rear differential, along with the transfer case, correct?
    - Fourth question
    The transmission calls for a GL4 gear oil. Redline MT90 seems to be a good option. Does anyone have any objections or suggestions.
    Thanks
  2. Dec 22, 2014 at 9:10 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I just go to the dealer and tell them what fill/drain plugs I need and the gaskets.
    They have a nice diagram they can show u so u both agree on the part#
  3. Dec 22, 2014 at 9:15 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  4. Dec 22, 2014 at 9:26 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Im looking for more and drawing a blank
  5. Dec 22, 2014 at 9:27 PM
    steveo27
    Pittsburgh
    Thanks for the info!
  6. Dec 23, 2014 at 12:09 AM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Make sure you remove the fill plug before the drain plug,,,
    If you drain and can't get the fill plug out your screwed
  7. Dec 23, 2014 at 6:22 AM
    steveo27
    Pittsburgh
    Yep, thanks for the bit of advice. Thats part of the reason for me replacing all the plugs. :beer:
  8. Dec 23, 2014 at 1:08 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    bump for more info
  9. Dec 23, 2014 at 2:20 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Knock on wood but I haven't changed the washers on this truck or my last.
    I used Redline synthetic oil for all the running gear. The transmission did seem to be a little smoother after.
    Only thing I would add is to have a good pump and some oil to fill everything back up, it helps a lot.
  10. Dec 23, 2014 at 2:30 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I used Redline MT-90. It's good stuff! My gears were noticeably smoother but then again I had 155,000 on factory tranny fluid. :eek:
  11. Dec 23, 2014 at 7:50 PM
    steveo27
    Pittsburgh
    Thanks for the info guys.
    I pulled the trigger on 2 quarts of Redline MT90 for the transmission so far. I need to order all the gaskets and plugs once I get all the parts numbers sorted.
    Also, Ive updated the list with some more part numbers. So far, I have everything sorted but the gaskets and plugs for the transmission.
  12. Dec 23, 2014 at 8:48 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    good to hear somebody actually still cares about this stuff.
    im also in the class of people who dont replace sealing washers and no leaks if you care to know.
    gear oil is expensive enough!
  13. Feb 11, 2015 at 6:05 PM
    53flattie
    53flattie Well-Known Member
    Upstate, SC
    2006 DC
    2.5" OME
    Maybe a dumb question, but from what I'm seeing, the front diff and tcase use 75w90; the transmission and rear axle call for 70w90. They all vary in capacities, but the sum total is just under 2 gallons. Would it be a problem to just run 70w90 or 75w90 in all four components, so as to just be able to buy 2 gallons of the same gear oil? Unless I'm mistaking, the two oils are pretty much exactly the same except one is slightly thinner when cold. I live in the southeast, so extreme cold temperatures are not something I have to worry with.
  14. Feb 11, 2015 at 6:35 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  15. Feb 12, 2015 at 11:57 AM
    53flattie
    Upstate, SC
    2006 DC
    2.5" OME
    Thanks Ken. Mine is a 2006 with the rear locker (TRD OR). I have changed the gear oil in the rear axle, but I can't remember if I needed an additive? I'm thinking that the locker in those years didn't have a limited slip built in. Is that correct?
  16. Feb 12, 2015 at 12:00 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    No additive needed
  17. Feb 12, 2015 at 12:04 PM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    I can tell you this since I just did my front, rear and transfer case.. Get an extra bottle of fluid because my rear end and transfer case took a little more than expected. Not sure if this is because I kept pumping while it was dripping down to make sure or if it is because my little pump thing that screws into the bottle doesn't get it all. When I started sucking air, I stopped and poured the rest of that bottle into another and kept going. Hard to tell exactly how much went in but I know it was more that I was originally planning.
  18. Feb 12, 2015 at 2:36 PM
    53flattie
    Upstate, SC
    2006 DC
    2.5" OME
    I remember this happening to me the last time. That's why I was thinking that 2 gallons would be good. The total capacity is actually 7.6 quarts, which would leave almost half a quart "extra".
  19. Feb 12, 2015 at 2:37 PM
    53flattie
    Upstate, SC
    2006 DC
    2.5" OME
    Thanks Justus!
