Gear oil or tranny fluid??
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2studley2, Jan 14, 2016.
  1. Jan 14, 2016 at 11:14 AM
    2studley2
    2studley2 [OP] Member
    Jeff
    99 Tacoma TRD SR5
    about to service the transmission on my 99 taco. It's a 5 speed manual and I was told by a shop it takes transmission fluid. Just wanted to see if anyone has any input.
    I know in some cases manual trannys will use tranny fluid but it's pretty rare.
  2. Jan 14, 2016 at 11:16 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  3. Jan 14, 2016 at 11:19 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    This is not one of those tranny that takes ATF it take what @thunderone said.
    Norton likes this.
  4. Jan 14, 2016 at 5:02 PM
    2studley2
    Jeff
    99 Tacoma TRD SR5
    Thanks! One last question.
    I'm also changing my differential fluid. Does 75/90 sound correct?
  5. Jan 14, 2016 at 5:06 PM
    Speedytech7
    Yup, use GL-5 in those though.
    Norton likes this.
  6. Jan 14, 2016 at 8:30 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    You can use regular GL-5 in your transmission just fine, saying otherwise is a Tacoma wives tale.
    If you use synthetic, GL-4 is recommended to avoid possible minor shifting irregularities. Results vary.
    I use 75w-90 GL-5 in everything just to keep it simple and change it out ~25k T-case and rear diff and ~50k tranny and front diff. My other truck uses the same oil, so I buy the shit in bulk.
  7. Jan 14, 2016 at 9:30 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    This is why I just use GL4/5 :D can't argue with that
    Norton likes this.
  8. Jan 15, 2016 at 5:02 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Interesting. Coming from working on mostly DTM cars. Most of their manuals use ATF equivalent to whatever the a/t for that model uses. Usually its Dex3 for LT71141 standard. Only since 2010 or so have i seen BMW and Mercedes start to go to gear oils, mostly GL-4 or GL-5 spec.
    Just find it interesting.
  9. Jan 15, 2016 at 5:18 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    I bet the owners manual tells you what kind of oils to use?
    Norton likes this.
  10. Jan 15, 2016 at 2:34 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Usually not for a manual transmission since there isn't a dipstick
  11. Jan 15, 2016 at 2:50 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    As a matter of fact, it does. (Yes, I realize the attached excerpt is from my '04 Owner's Manual but, having seen the same information in my son's '01 Owner's Manual, I'm relatively certain it's available in all of them.)
    What does the absence or presence of a dipstick have to do with whether the Owner's Manual provides lubrication specs?
    Speedytech7 likes this.
