gear oil question
Discussion in '1st Gen. Tacomas (1995-2004)' started by tsab916, Mar 15, 2011.
  1. Mar 15, 2011 at 8:27 PM
    tsab916
    tsab916 [OP] Well-Known Member
    Sacramento
    02 DC 4x4
    What weight gear oil do you guys use?
    - I just changed my rear end fluid today at work (did it while the bosses weren't around) and had one he'll of a time because I had no pump and the spare tire was in the way, so I ended up just using what we had in a 55gal drum which was 80w-140 only because it had a pump.
    Can anything happen to the diff if the gear oil you use is to heavy?
  2. Mar 15, 2011 at 8:48 PM
    tsab916
    Sacramento
    02 DC 4x4
    I think first gen uses 80w-90...
    My question is is there any harm in using a heavier weight gear oil?
  3. Mar 15, 2011 at 8:50 PM
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    i think it'll just be working harder because of the thicker oil
  4. Mar 15, 2011 at 11:37 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  5. Mar 16, 2011 at 1:03 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    MPGs and power will drop. I don't *think* anything will break...
  6. Mar 16, 2011 at 3:49 PM
    tsab916
    Sacramento
    02 DC 4x4
    Yea...im just gonna run the 80w-140 for a few days to I guess rinse the diff and change it to 80w-90 later....thanks for the inputs guys
