Gear Oil Question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaZL, May 4, 2015.
  1. May 4, 2015 at 6:56 PM
    TacomaZL
    TacomaZL [OP] Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    So I have been reading alot of threads on this forum concerning gear oil and what works and what doesn't; As soon as I think I have it all figured out, I read something contradictory. So here's my question:
    I have a 2013 Tacoma Base Model, do I have an LSD? I heard 2009+ models have mechanical LSD's....so do I need an additive when changing the fluid out? Or can I use straight gear oil? My final question is can I use conventional, or should I go with synthetic? I've heard that synthetic can wreak havoc on certain differentials, but not sure if mine falls into that category?
    Thanks to all who post in advance!
  2. May 4, 2015 at 7:32 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    08- trucks can have a mechanical LSD depending on options (unless its a TRD OR with the elocker which NEVER had a mechanical lsd)
    09+ trucks DO NOT have a mechanical lsd, you can use any standard gear oil in ANY 09+ truck.... personally i run mobile 1 synthetic gear oil which just so happens to have LSD additives, but is not needed in my 2013 TRD OR.
    That stated.... get what ever oil you want... The real key is CLEAN FRESH oil and PROPER changes. I changed my rear diff oil at 6k miles ... shit came out DISGUSTING from break in, super glad i changed that shit out.
  3. May 4, 2015 at 7:33 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
  4. May 4, 2015 at 8:03 PM
    TacomaZL
    Illinois
    Thanks nd4spdbh and File IFR, I must have mixed up the mechanical LSD dates then. Thanks for the fast responses from both of you guys.
