Gear oil question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Greenbean10, May 28, 2025.
  1. May 28, 2025 at 11:03 AM
    Greenbean10
    Greenbean10 [OP] Well-Known Member
    2010 Timber Mic 4x4
    Hello everyone. Can someone advise me on whether or not having limited slip additive in gear oil is going to ruin my front/rear diffs and transfer case? LS additive is not needed for my particular truck i know that for a fact, but I cannot find any gear oil anywhere that does not contain LS additive.
    Has anyone noticed a difference with using a gear oil with the additive versus not with the additive?
    Thank you!
  2. May 28, 2025 at 11:07 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    The easiest and best way to determine what specific type of oil you need is to click the "Find Products for my Vehicle" and enter your truck information. It will answer your questions.
    https://www.redlineoil.com/
    I don't think it makes a difference in your diffs, and probably not in your transfer case. It will in a manual transmission, since you need GL-4 in that.
    O'DubhGhaill likes this.
  3. May 28, 2025 at 11:09 AM
    Bishop84
    Bishop84 Well-Known Member
    It doesnt make a difference, ideally you want simple GL5 for front and rear and GL4 for transfer case. (you can use GL5 on the tcase but its not ideal)
    The additives won't hurt anything, just makes it more expensive.
    O'DubhGhaill and 2015WhiteOR like this.
  4. May 29, 2025 at 7:43 AM
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    No , it won't hurt ... We use X brand of a 75-90 oil in all our truck and SUVs (millions of miles) and no problem of any kind. It says "limited slip additive". I was gonna add recommendation here but the thread would have been hi jacked !
  5. May 30, 2025 at 6:02 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    Redline 75w90 is GTG for front and rear diff, and their formula negates the need for LSD additive. Redline MT90 for the trans and transfer, 6spd manual. Life is good.
  6. May 30, 2025 at 6:45 PM
    545 Well-Known Member
    2015 Access Cab
    Nah, doesn’t matter for non limited slip, which is why a lot/ most oils just include it, works fine for both
  7. May 31, 2025 at 6:43 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I actually never heard of using GL4 instead of GL5 in the T case. I’ve always used GL5 as the owners manual specifies GL5, did they change the recommendation for 2012-2015 Tacamos? Thanks
  8. May 31, 2025 at 7:33 AM
    Bishop84
    I used 75W90 GL5 on all my Toyota transfer cases. Every dealer uses GL5.
    Technically you're supposed to use a straight 75W LF transfer fluid$$$$ but GL4 is closer to that oil.
    The thing is, the transfer case doesn't do much, especially in warm climates, so there's very little cause for concern with fluid choices. It's just a giant chain submerged in oil.
    I believe the new trucks use WS ATF fluid now, probably in an effort to reduce drag.
    Micbt25[QUOTED] likes this.
