Gear oil questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItsPattyPat, Feb 20, 2024.
  1. Feb 20, 2024 at 4:54 AM
    ItsPattyPat
    ItsPattyPat [OP] Member
    2015 TRD off road
    So I have searched through the forum and I am doing a fluid change on my transfer case, and front and rear diff. I am going with 75-90w oil. I wanted to use mobil1 but they all say they have LS additive. Is this an issue? I have a 2015 trd off road 4x4.
  2. Feb 20, 2024 at 5:22 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    It won't be a problem. Lots of members have used mobil1.
    ItsPattyPat[OP] likes this.
  3. Feb 20, 2024 at 5:27 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    All is good brother.....I used modil1 the first time I change mine.
  4. Feb 20, 2024 at 5:55 AM
    ItsPattyPat
    2015 TRD off road
    Ok so does the LS additive matter? Because I saw for the sports they need to add LSD. So I guess I’m wondering if the LS additive that’s already in the oil hurts or not and if I have to find one without it
  5. Feb 20, 2024 at 6:00 AM
    ItsPattyPat
    2015 TRD off road
    Ok thank you! But is the LS additive an issue?
  6. Feb 20, 2024 at 6:01 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Sports from 12 years ago needed additional LSD additive beyond the small amount in the bottle. Later Sports changed to brake-based simulated LSD like the other trims.
    The LSD additive in the bottle won't do any harm.
  7. Feb 20, 2024 at 6:08 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    same model as you, same fluid, no issues
  8. Feb 20, 2024 at 6:15 AM
    ItsPattyPat
    2015 TRD off road
    Ok thank you for the help
  9. Feb 20, 2024 at 6:15 AM
    ItsPattyPat
    2015 TRD off road
    Ok thank you !
  10. Feb 20, 2024 at 11:10 PM
    TacoTuesday1
    SD CA
    LSD oil is for clutch LSD's. According to Amsoil, accidentally putting some into a regular diff won't harm anything.
