Gear oil smell no leaks
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scott54, May 18, 2020.
  1. May 18, 2020 at 10:26 AM
    Scott54
    Scott54 [OP] Member
    Scott
    1997 Tacoma
    Help needed on my 300k 1997 3.4L manual taco...
    I'm smelling very strong, nasty whiffs of gear oil while driving, but no visible leaks. It started after changing the fluids in the transfer case and differentials, months ago. No smell in the cab, only under the truck body. Oddly enough I smell it when depressing the clutch. New clutch as of a week ago, thinking maybe I smelled the clutch slipping, but that wasn't it. No visible leaks. Any ideas?
  2. May 18, 2020 at 10:31 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Have you replaced the valve cover gaskets? They could be leaking, mine does and you can smell the oil. They're getting replaced soon :thumbsup:
  3. May 18, 2020 at 10:33 AM
    Scott54
    Scott54 [OP] Member
    Scott
    1997 Tacoma
    Valve cover gaskets replaced about a month ago. What I smell isn't that oil though, it's gear oil. The nasty pungent smell
  4. May 18, 2020 at 10:52 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    It might be just from whatever spilled out when you did the fluid change. The nasty smell is sulfur in the gear oil; its there as a pressure additive. If its just from spillage it will get weaker over time.
    tacotoe likes this.
  5. May 18, 2020 at 1:39 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    When you roll your window down does it smell like you are driving near a cow pasture?
  6. May 18, 2020 at 3:07 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    As things warm up with warmer weather pushing fumes out the vent perhaps.
    Do you smell it when parked ?
    There are many smells worse then gear oil it smells good to me any more
    tacotoe likes this.
  7. May 18, 2020 at 3:09 PM
    eon_blue
    Azusa, CA
    I had a trans shop overfill my manual trans with gear oil when they replaced the clutch. It smelled like gear oil bad inside my truck when the trans heated up on a long drive. Could smell it from the shifter area.
    They were able to overfill it because they filled it from the top (not using the fill hole on the trans). Did you recently change your fluids or did a shop do it?
    catskill.joe, tacotoe and Wyoming09 like this.
  8. May 18, 2020 at 5:55 PM
    cast718
    cast718 Well-Known Member
    New Jersey
    2004 4WD Standard Cab 4 Banger
    I recently did all my gear oil swaps and smelled it just like you, maybe not so bad. I'm 99% sure its just whatever you spilled. As you know that smell is strong and unmistakeable.
    tacotoe likes this.
  9. May 18, 2020 at 6:14 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    It will fade, mine stunk for weeks when I first changed the trany/transfer and differentials.... the stink kinda clings to everything, like if you run over a dead skunk. Get a little green tree ... lol
    tacotoe likes this.
  10. Jul 28, 2020 at 11:23 AM
    coopjl
    coopjl Well-Known Member
    Jeff
    Fairbanks, Alaska
    2014 Double Cab
    ARB Deluxe bull bar ARB Fog lights ARB Driving lights 24" Vision X Light bar ARB Rear locker w/4.56 ARB Front locker w/4.56 ARB Compressor Warn M8000# winch OME HD suspension CBI rock sliders CBI Trail Rider rear bumper with tire carrier and fuel can carrier Lear Topper with wilderness package TRD Matte Black Wheels SlimLine FrontRunner II Roof rack
    My 2014 has this problem also.
    No leaks and it is definitely gear oil not motor oil.
    I am the only person that services this vehicle and I am certain that it is not over serviced
  11. Jul 29, 2020 at 8:36 AM
    skeezix
    Colorado
    1998 Limited
    Well it's been over ayear now and I still can smell the gear oil. And still no signs of oil leakage anywhere underneath the truck or in the engine compartment. Funny thing is, during last winter I didn't smell it at all...:notsure:
  12. Jul 29, 2020 at 9:14 AM
    eon_blue
    Azusa, CA
    Warm/hot weather makes it smell more I bet, makes everything smell more lol.
  13. Jul 29, 2020 at 9:40 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    torn rubber manual shift boot
  14. Jul 29, 2020 at 2:09 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    The gear oil smell usually hangs around for a little while. When I did mine, I cleaned as much of the gear oil off as I could with brake clean but there was still a hint of the smell which went away gradually over time. Just keep an eye and make sure you have no leaks.
  15. Sep 14, 2020 at 9:52 AM
    Jacob
    Jacob Well-Known Member
    Does anybody have any more insight on this one? I changed all my gear oil earlier this summer (front and rear diffs, manual trans and transfer case), and I have the exact same issue. I especially notice mine when I'm under load at altitude, ie going up steep hills. I'm not getting any leaks, and I filled them from the side ports. I measured my oil per the owners manual to make sure I didn't overfill. It's been several months but still very noticeable... it's driving me crazy.
  16. Sep 14, 2020 at 9:59 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    How are the breather caps and lines? Did you do a rear diff breather relocate?
    It's also possible you just used more volatile gear oil with more sulfer content than the previous oil. I notice Castrol synthetic smells worse than Lucas or Pennzoil/Quaker/Shell synthetic, for example.
  17. Sep 14, 2020 at 10:05 AM
    Jacob
    I did the rear breather mod as well, and located along the gas filler neck under the bed (I didn't bore through to the gas cap). Front breather was still fine.
  18. Sep 14, 2020 at 10:05 AM
    Jacob
    I feel like I can smell it coming from the my shift lever - I've yet to tear apart my center console.
  19. Sep 14, 2020 at 2:39 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Spilled some gear oil on the carpet about 6 years ago. When the heats on blast it stinks sometimes. lol You might have too much in there and it's making it's way out the shifter area.
  20. Sep 14, 2020 at 2:44 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Might be a cracked transmission breather line?
