Gear Oil - Synthetic or Not?
Discussion in 'Technical Chat' started by Scott B., Jan 27, 2016.
  1. Jan 27, 2016 at 5:47 AM
    Scott B.
    Scott B. [OP] Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    As the title states, I am wondering about using synthetic gear oil in my axles.
    I have used Valvoline synthetic gear oil for many years and several hundred thousand miles in other trucks with absolutely no issues. I have no hesitations about using it.
    However, I had East Coast Gear Supply (ECGS) build my differentials with 4.56 gears, and they recommend not using synthetic. They recommend Lucas gear oil. I know Lucas is good oil (and a lot less expensive than synthetic.) I asked them why their recommendation was non-synthetic, but did not get a satisfactory answer.
    I am getting ready to change the axle oil, and am wondering if I should switch to synthetic.
    Any thoughts and/or experiences, good or bad?
  2. Jan 27, 2016 at 5:53 AM
    Erkon
    Erkon Well-Known Member
    Wisconsin
    2012 Pyrite Mica Tacoma TRD Supercharged
    Not sure about your set up but I installed Lucas 75w90 Synthetic in my STOCK diff. I will be doing the t-case and front diff soon.
