Gear oil?
Discussion in '1st Gen. Tacomas (1995-2004)' started by AZTacoSupreme, Apr 13, 2014.
  1. Apr 13, 2014 at 12:08 PM
    AZTacoSupreme
    AZTacoSupreme [OP] Well-Known Member
    Anthony
    Chandler, AZ
    2006 LS430/ 2004 Sequoia 4X4
    Still trying to get my tacoma up to par, and am going to change the gear oil, as well as flush the trans. But I was told to use 90w gear oil and I can't find it anywhere. My truck is a 99 prerunner with the e locker in it, so I do not need a friction modifier but I'm just wondering what gear oil I should use since I can't find 90w, and if synthetic is worth it?
  2. Apr 13, 2014 at 3:54 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I run Amsoil Severe Gear 75W-90.
    IMO, synthetic is worth it. See this for complete recommendations.
  3. Apr 13, 2014 at 9:17 PM
    AZTacoSupreme
    Anthony
    Chandler, AZ
    I looked into Amsoil but couldn't find their stuff at o'reillys so I'm running mobill 1 75-90, just out of curiosity how often should I change my diff fluid?
  4. Apr 13, 2014 at 9:25 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    That's what I used for mine this past fall. Mobil 1 Synthetic 75w90 in the rear, center, and front diffs. And I think it's Dex 3 or 4 now for the ATF? Look in your service manual but I believe it's every 30k or 50k. I did mine @ 110k cause she was mainly a street/highway queen :p
  5. Apr 13, 2014 at 9:32 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    I run Valvoline 75-90 dino gear oil. I off road the shit out of my truck. You will be fine running dino gear oil don't waste your money on the over priced over hyped synthetic.
  6. Apr 13, 2014 at 9:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Toyota recomends changing the rear diff gear oil every 30K. IMO, it really depends on how you use your truck. If it is your daily driver, then every 30K miles is adequate. If your truck sees a lot of offroad use, then more often is probably better.
    The main advantage to synthetics is they usually have better shock absorption and heat dissipation properties. Synthetics are worth it if you use your truck hard.
    My personal choice is Redline 75w90. http://www.redlineoil.com/product.aspx?product=57904
    My local source is Carquest Auto and I use Amazon for an online source.
    http://www.amazon.com/Red-Line-57904-Synthetic-Oil/dp/B000CPCBF0
  7. Apr 13, 2014 at 9:41 PM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    !st gens do just fine with non-synthetic. That's what they came with. Use what you want. Been turning wrenches for close to 25yrs for a living. Do lots of oil samples on customer equipment. Some run synthetic some don't. Have not seen any less wear with synthetic oil in those engines or transmissions.. Like I said I wheel my truck harder than most and have never had gear failure due to using non-synthetic oils
  8. Apr 13, 2014 at 9:51 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That's the beauty of tacomaworld. Everybody has a personal opinion. Good to hear that dino oil has been working out for you man. :cheers:
  9. Apr 13, 2014 at 9:58 PM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    No worries.
  10. Apr 13, 2014 at 11:56 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I also just stick with the good old stuff. Just change it out on time.
  11. Apr 14, 2014 at 2:38 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I run 80/90 dino.
    Recommended by a long-time professional gear-box mechanic
  12. Apr 14, 2014 at 5:03 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
  13. Apr 14, 2014 at 5:15 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Isn't the whole purpose of synthetic that you can run it a lot longer than dino?
  14. Apr 18, 2014 at 8:19 PM
    Norton
    I wouldn't say that's the "whole purpose" but it's definitely one of the benefits.
    Synthetic lubricants also offer better detergent properties (cleaner running), lower pour point (better cold flow properties), higher TBN (improved resistance to acid formation), and lower NOACK volatility (less evaporation).
  15. Apr 20, 2014 at 9:18 AM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    All this and at the end of the day I have had to rebuild engines and transmission that were run on synthetic oil that were no where near the engine life expectancy. Oil samples are your best indication of wear. I do shit loads. I work on engines, transmission and generators for a living. Hell I own the business. . Like I have stated before I have seen no benefit from synthetic oil. I know this from experience not just some sales pitch from a commercial or sales man. But real life experience working on servicing and rebuilding engines for a living.
  16. Apr 20, 2014 at 11:43 AM
    Coppertone
    Coppertone Well-Known Member
    South Louisiana
    2021 Tacoma DCLB TRD OR
    Are you suggesting that there are no real world differences between off brand oil from Dollar General and Mobil One Extended Performance Synthetic?
    Interesting (no sarcasm).
  17. Apr 20, 2014 at 12:04 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I run this in my rear diff, front diff, and transfer case. I use mt90 in my 6speed. you can probably guess i like redline... if you get redline get the "NS" formula as they dont have the friction modifier. Also id get 75-140 like the link takes you to. the 140 is nice piece of mind when pushing the truck hard and I still get the same gas milage as with a 75-90...
    http://www.redlineoil.com/product.aspx?pid=39&pcid=4
    but really its not necessarily the oil that really matters, just change it regularily...
  18. Apr 20, 2014 at 10:26 PM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    What I am saying is I do tons of oil samples on engines. We don't use dollar general oil. But all that matters with oil is the API rating.
