Gear Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maunal4life, May 17, 2019.
  1. May 17, 2019 at 7:10 PM
    maunal4life
    maunal4life [OP] New Member
    Jake
    2006 Orange taco 4x4 manual
    So I'm wanting to change the gear oil on the front diff, rear end, and transmission (5 speed 4x4)
    How much gear oil I will need for all three, and do you have to run different weight gear oil in them?
    Truck is an 06 single cab 4x4 manual.
    Thanks.
  2. May 17, 2019 at 7:23 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
  3. May 17, 2019 at 7:31 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I seem to remember the transmission needing GL-4 where GL-5 is fine in diffs. Gonna go grab my manual to double check that.
    Edit: Just confirmed in my manual GL-4 in the trans, GL-5 in the Diffs. Hit the transfer case while you are at it. 75-90 on all 3. The manual actually calls for 75-85 in the diffs but that is a bunch of horse shit to get you to buy the Toyota fluid.
    outlawtacoma and maunal4life[OP] like this.
  4. May 17, 2019 at 7:35 PM
    Clearwater Bill
    Billy
    Largo Florida
  5. May 17, 2019 at 7:35 PM
    KaPantsKey
    KaPantsKey Well-Known Member
    Kyle
    SC
    13 MGM DCSB TRD-OR
    I assume you mean the transfer case when you say transmission? If that is correct, I purchase 6 quarts to do all 3 (front diff, transfer case, and rear diff). I use Mobil1 75W-90, but that is up to you. Do make sure your rear diff requires LSD additive, or not. I can't remember if the 2006's need them.
    Biscuits likes this.
  6. May 17, 2019 at 7:48 PM
    Biscuits
    That is what I assumed.
  7. May 17, 2019 at 8:17 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I use 75 90 in my rear diff front diff and transfer case.
  8. May 17, 2019 at 8:34 PM
    maunal4life
    Jake
    It's a manual transmission so I'm trying to figure what gear oil to put in it. I've got the 75W-90 for the diffs and transfer case.
  9. May 17, 2019 at 8:35 PM
    Biscuits
  10. May 17, 2019 at 9:51 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    We've got a barrel of 80w-90 in the shop and i just use that cause its free
    spitdog, Mickeydog and Biscuits like this.
  11. May 28, 2019 at 11:52 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    75W-90 is suitable for the transmission, transfer case, front diff, and rear diff.
    FWIW, I've had good results with Amsoil Severe Gear 75W-90 in all of the above for years in my previous 1st Gen and my current 2nd Gen.
    b_r_o and Biscuits like this.
