Gear question???
Discussion in '1st Gen. Tacomas (1995-2004)' started by jeff6001, Jul 4, 2009.
  1. Jul 4, 2009 at 2:56 PM
    jeff6001
    jeff6001 [OP] Well-Known Member
    San Antonio, TX
    99 trd prerunner
    So my dad wants to put a nice 6" lift on 95 4x4. He would like to run 35's on it and use it as a hunting/farm truck. The lease is in the hill country and just to make it easier we are installing 4.88 replacement gears. We are going to be driving this truck back and forth from our house to the lease and was wondering would the new gears help keep the MPG the same or would the 35's still run it into the ground???? Any suggestions or help would be appreciated.
  2. Jul 8, 2009 at 9:43 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    03 DCSB
    magnaflow cat back exhaust, K&N filter, gray wire, deck plate, ome 883's, ome dakar leafs, bilstien 5100's, blacked out grille, AVS bug shield & window vents, arb bull bar, hella 5in lights, mile marker 8k winch, debadged tailgate, energy steering rack bushings, custom rear bumper w/ hidden receiver, custom headache rack, ome greasable shackles, 4.88's w/solid spacer, SS extended brake line
    definatly need gears 5.29 but they are very pricey
  3. Jul 9, 2009 at 1:44 PM
    JVTACOMA
    JVTACOMA Well-Known Member
    4:56 OR 4:88, I would go more with the 4:88. 5:29's only if it will never see black top. if you're doing that kind of lift with 35's fuel milage should be the least of your worries!!!! i vote for 4:88's!!! good luck. Check this link, it explains things pretty well and gives you some formulas to check out!!!
    http://www.4x4offroads.com/gear-ratio-chart.html
