Gear Ratio for 1999 Tacoma Sr5 4WD
Discussion in '1st Gen. Tacomas (1995-2004)' started by ConnorC223, Aug 3, 2022.
  1. Aug 3, 2022 at 10:42 PM
    ConnorC223
    ConnorC223 [OP] New Member
    Hey I’m new to tacomas used to be a jeep guy. I currently am running 235/65/17s on my 1999Tacoma SR5 4WD 2.7 L. ( I use this vehicle as a daily driver) I’m looking to have this tire size be the smallest I go and have the ability to run 33” tires. I have a 2 inch lift, I have plenty of space for bigger tires. I don’t want to overdose my tires, and break my gears like I’ve done in the past. Does anyone have any suggests on what gearing I should switch to? Thanks a lot. Looking to have proper gearing to save a tiny bit on gas, have a more comfortable ride, and have the ability to run big tires. I don’t need to go much past 33”. Let me know!
  2. Aug 3, 2022 at 11:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is it an auto or a manual trans?
  3. Aug 4, 2022 at 7:11 AM
    ConnorC223
    5 speed manual
  4. Aug 4, 2022 at 8:41 AM
    Digiratus
    Roaming the PNW
    The RedHead
    4.88s for 33s. 5.29s if there is any chance you'll ever go bigger than that.
