Gear ratio issue in mountains
Discussion in '1st Gen. Tacomas (1995-2004)' started by galius42, Aug 17, 2017.
  1. Aug 17, 2017 at 3:32 PM
    galius42
    galius42 [OP] Member
    Truck is '03 2.4l RWD 5-speed manual--All stock everything
    With the stock 3.58 gears I can barely make it up my driveway (215/70R15 tires).
    What's my best option here? I assume a gear change. Which gears will be usable? Axle code is A02A.
  2. Aug 17, 2017 at 5:02 PM
    Indy
    Indy Master of all I survey.
    That's the stock tire size?
  3. Aug 17, 2017 at 6:26 PM
    galius42
    Door sticker lists 205/70 R15
    Pretty darn close, at any rate.
  4. Aug 17, 2017 at 6:33 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    It's either stock or very close, OP has a 5 lug taco which has itty bitty tires.
    I understand your issue OP, I had a 95.5 with the 2.4 and 5spd and had a very steep driveway as well.
    I think 3.73 gears would work without killing your top end.
    The 2001-2004 2.4's with the auto trans came with 3.73's, you may be able to find a rear ring and pinion set from one that somebody pulled out.
  5. Aug 17, 2017 at 6:36 PM
    Clearwater Bill
    Billy
    Largo Florida
    Barely make it up your drive in 1st gear?
  6. Aug 17, 2017 at 6:50 PM
    galius42
    Yeah. It's steep enough that most autos bottom out pulling in.
    Just measured: 15 degrees, which is 26.8% slope.
    Dalandser likes this.
  7. Aug 17, 2017 at 7:22 PM
    95 taco
    95 taco Battle Born
    First gear is fairly tall in the 1st gen 5 lugs, I would equate it to 2nd gear in a dodge 5.9 with the 5 speed.
  8. Aug 17, 2017 at 7:37 PM
    galius42
    I was assuming I would have to go to at least 4.10 to even notice a difference. Is such a small change noticeable?
  9. Aug 17, 2017 at 7:39 PM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    They use 4.10s as a stock gear ratio in 2nd gen 5 lugs.
  10. Aug 17, 2017 at 7:44 PM
    95 taco
    95 taco Battle Born
    3.58 to 3.73 would be a 4.02% change
    3.58 to 4.10 would be a 12.68% chance
    I don't know if 4% would be enough of a change but I think 12.5% would take too much from the top end if you do much highway driving.
  11. Aug 17, 2017 at 7:44 PM
    Hilborn
    Michael
    Utah
  12. Aug 18, 2017 at 1:41 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It comes down to what your other driving is like .
    Gearing is always a comprise you give up something to get something else
    Are your trips of only a few miles (5 to 10)??
    Long like 100 miles a day??
    As the gear ratio goes up the rpm increases for a given road speed to some the extra fuel is no big deal to some it is major
    In my case another $100.00 or so a month would be just a bigger check each month
