Gear ratio
Discussion in '1st Gen. Tacomas (1995-2004)' started by blaib, Sep 1, 2015.
  1. Sep 1, 2015 at 5:15 AM
    blaib
    blaib [OP] Active Member
    Brian
    Is there an option sticker on these Tacoma's that give the gear ratio like GM vehicle's do if you know the RPO code?
    Mine is a 98
    Thank you
    Brian
  2. Sep 1, 2015 at 5:17 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
  3. Sep 1, 2015 at 7:55 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    There is a code on your door sticker. Then look at the sticky at the top of the page to see what ratio ya got.
  4. Sep 1, 2015 at 10:18 AM
    blaib
    Brian
    Thank you I will try the vin check thing. Bry838 I did find that sticky looked on my door label but I do not see anything that starts with A Or B and than any numbers after it.
  5. Sep 1, 2015 at 12:06 PM
    bry838
    oregon
    Well shit! I think I remember hearing/reading that some stickers had a ? Instead of the code. Did u c a ? On the sticker??
  6. Sep 1, 2015 at 12:37 PM
    blaib
    Brian
    Did the vin check thing also, had a lot of info but nothing about gear ratio, LOL. Just my luck. Yes there is a ? there and no info. Strange any other idea's?
  7. Sep 1, 2015 at 1:14 PM
    bry838
    oregon
    Well I'm not privy to the process but I do know u can jack up the rear and turn the tire by hand and count the revolutions of the drive shaft. But idk anything about that other than its a way to figure out your ratio. Hopefully someone else will chime in with the true knowhow of this method...
  8. Sep 1, 2015 at 2:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Put a chalk mark on your driveshaft and your tire. How many revolutions of the driveshaft does it take to make one revolution of the tire?
    More info about your truck? v6 or i4? Manual or auto trans? Reg cab, x-cad or d-cab?
    On the drivers door jam sticker what is written next to AT/M
  9. Sep 1, 2015 at 3:07 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Zactly, lets have it.
  10. Sep 1, 2015 at 3:11 PM
    bry838
    oregon
    Do u guys just read the last posts of a thread?
  11. Sep 1, 2015 at 5:19 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    VIN does not show axle code or transmission. Not sure how that rumor ever started.
    I've attached an image of my door sticker. It shows my axle as B04A (4.56 gears)
  12. Sep 1, 2015 at 5:32 PM
    blaib
    Brian
    Ok guy's. It is a 98 Ext cab 4X4 2.7 engine standard transmission here is a shot of my door stickerIMG_0555.jpg
  13. Sep 1, 2015 at 8:10 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    I think you can look up where it says RZN171...... I believe your gear ratio is tied to that code as well.
    I've never seen one with a ? before.
  14. Sep 1, 2015 at 8:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hmmm.... mystery gears. 4 revs of the driveshaft for a single, full rev of the tire gives you a 4:1 ratio. A common gear set for Tacomas was 3.90:1. Also 4.10:1 was common with the TRD v6s. If you get 4.5 revs of the shaft, probably 4.56:1 ratio, a common one with the 2.7L/5-speed combo. Some have also reported having 3.53:1 ratio with the 2.7L.
    The only other way to know for sure is to pull the third and count the teeth. My guess is that you don't want to know that badly.
  15. Sep 1, 2015 at 8:17 PM
    ToyoTaco02
    Scott
    Decatur,IL
    From doing a little research it looks like 97-99 trucks with the 2.7L 5 speed came from the factory with 3.91 gears.
  16. Sep 1, 2015 at 8:18 PM
    ToyoTaco02
    Scott
    Decatur,IL
    I'm pretty sure 4.56 gears only came in 2.7L automatics.
    Snowman likes this.
  17. Sep 1, 2015 at 8:29 PM
    Fallguy6666
    Fallguy6666 Well-Known Member
    I don't know what my truck has in it....but it has zero problems turning the 285's that are on it.
  18. Sep 2, 2015 at 4:37 AM
    blaib
    Brian
    Yes I always get the weird stuff. Lol they just thought it would be funny to make this guy figure his gear ratio out.
  19. Sep 2, 2015 at 4:39 AM
    Fallguy6666
    I need to do the whole tire thing....I'm almost positive that its not the gears that the door says I have.
  20. Sep 2, 2015 at 8:08 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Special Order maybe? Might be calling a dealer will help, as they might know by the vin.
