Gear Ratio
Discussion in 'Performance and Tuning' started by steve0, Mar 14, 2016.
  1. Mar 14, 2016 at 6:52 PM
    steve0
    steve0 [OP] Member
    Steven
    mississippi
    50 Series Flowmaster k&n cold air intake Weather Tech Floor Mats 265/70R17 Yokohama M/T's
    What's the best gear ratio for 2nd generation taco's with tire size 285/70R17? Mostly in town, highway and some off road.
  2. Mar 14, 2016 at 6:54 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    If you have a v6 you'd be fine with your stock gears.
  3. Mar 14, 2016 at 11:31 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    not entirely true. If you absolutely had to regear, 4.10's would be amazing for 33s. stock gearing is great for stock size tires. But to retain OEM power, you want your gears set for the size tire you're running. You could possibly get away with 4.56 but you probably wouldn't be going much over 70 mph without being over 3K rpms.
  4. Mar 14, 2016 at 11:42 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    OP, your 285/70R17s are close enough to stock to not require regearing for normal driving situations. In fact you'll probably notice a small increase in MPG?
    Regearing is expensive and not an exact science. I'd avoid it if possible. Usually if you do rock-crawling and other intensive off-road, or you tow trailers you may find regearing necessary.
    For my money, if I was looking at a regear, I'd invest in a supercharger instead. Problem solved.
    numbah57 likes this.
  5. Mar 15, 2016 at 9:34 AM
    VolcomTacoma
    Jeff
    NorCal
    Not true, again. Regearing is the cheapest way to get your oem power back. Speaking from experience, a Supercharger doesn't give you all of your power back that you would normally have with an SC, and these days its way more expensive to boost than to regear. Without lockers a regear is maybe 2 grand, while an SC is about 6.
    Redsyota likes this.
  6. Mar 15, 2016 at 10:28 AM
    Redsyota
    Redsyota Well-Known Member
    Denver
    15' SPORT 6 SPEED ACLB MGM
    Some of the things...
    This is TRUTH! With 33" tall tires my s/c v6 manual could use more gear for sure. Stock tires with factory everything shows right around 2600 @70mph. Search the forum for feedback from guys running 4.56's and 33's (I'm pretty sure all of them are stoked).
  7. Mar 15, 2016 at 10:31 AM
    VolcomTacoma
    Jeff
    NorCal
    I have 295/75/16 (33.4") and I hate how much power I lost, with a Supercharged 6 speed (and all the other power adders) I might add. I'll be regearing with lockers as soon as I have the cash.
  8. Mar 15, 2016 at 10:39 AM
    Redsyota
    Denver
    My temporary solution was to get junkyard 4cyl diffs with reasonable miles and swap them but I'm afraid 4.10's won't be low enough. Locker's and 4.56's should be part of every standard tacoma build haha.
  9. Mar 15, 2016 at 10:42 AM
    VolcomTacoma
    Jeff
    NorCal
    Oh yeah 4.10s are good for 265/75/16 or so IIRC. and Agreed, lockers and gear of your choice :D
  10. Mar 15, 2016 at 10:45 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I've supercharged a 3.4 Tacoma and re-geared my current 2.7 Tacoma.
    S/C cost me $1700 used + $1000 for the 7th injector and pulley.
    New gears cost me $1150.
    Much better power gain with the re-gear over the S/C. Based on having done both, I'd do a re-gear any day before a S/C
  11. Mar 21, 2016 at 9:10 AM
    eze5601
    eze5601 Member
    Where do you feel the difference? I've done the same and to be honest with you I havent noticed a change. Maybe slightly on steeper grade inclines but i've never felt my truck had enough torque...
  12. Mar 21, 2016 at 9:26 AM
    boostedka
    James
    NM
    I feel like I notice a difference in all areas of driving. Around town, the truck requires less throttle to accelerate and much less throttle to maintain speed. On the highway, I'm not losing speed up hills and require less throttle to maintain speed. This has resulted in better mpg's as well. I went from 3.91's and 31's to 4.88's and 33/12.50 and my truck feels way more powerful and responsive than before. This is evident on my ultra-gauge by getting slightly better MPG's as before with a 2" larger (diameter and width) and 10lb heavier tire. I accelerate quicker and maintain speed better at a lower throttle position % than before.
  13. Apr 19, 2016 at 9:05 AM
    erval09
    erval09 Well-Known Member
    Montclair, CA
    06 Tacoma SR5, 2WD, 4cyl, 2.7L, 5 Lug, 5 speed manual
    I recently lifted my truck 3" and added 30" tires. I have a 2006 Taco 2wd 2.7L manual trans (5 lug) and I don't know what is the factory gear ratio. The VIN says A05A/R155 but I have no idea what that means.
    The stock OEM tires are 215/75R15. What new gears would you guys recommend to get back factory power (if not stronger but not too much because I want to keep decent gas mileage)? Would 4.11 gear work?
    And how much $$ will I be looking to spend? Thanks!
