gear ratios
Discussion in 'Performance and Tuning' started by grexwilbur, Feb 9, 2011.
  1. Feb 9, 2011 at 9:15 PM
    grexwilbur
    grexwilbur [OP] Member
    wilbur
    cape cod
    Tacoma sport
    TRD exhaust,Icon coil overs, Remore res icon rear,Alcan 10 leaf custom rear leafs,pro comp wheels, 285 70 17 Mickey Thompson mtz, afe air
    I put 285 /70/17. On my taco now feels like alot less pep and power. ..do most peep change rear axle ratios when goin bigger...if so what should i change it to and where can i get these gears? Will it mess w my warentee
  2. Feb 9, 2011 at 9:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    re gearing doesnt affect the warranty. For 33's, a 4.10 ratio would put it back to near stock. You could go with 4.56's if you want to be slightly over geared.
  3. Feb 9, 2011 at 9:30 PM
    grexwilbur
    wilbur
    cape cod
    Tacoma sport
    So are these toyota gears or aftermarket..do i need to change front as well to match? Also by not changing am i hurting anything...feels like im boggin engine more. Cause lower rpms if i go 4:10 will that give better off road performance?
  4. Feb 9, 2011 at 9:40 PM
    grexwilbur
    wilbur
    cape cod
    Tacoma sport
    One more question. Any one know what kind of $ talkin to change gearing
  5. Feb 10, 2011 at 6:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Re gearing will give better performance all around. Cost is between $500.00 and $700.00 per axel. Yes, If your 4x4, you need to change out the front and rear.
  6. Feb 14, 2011 at 3:20 PM
    accesscab
    accesscab Well-Known Member
    What is the factory ratios?
