Gear ratios
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lifted blue limo, Dec 11, 2019.
  1. Dec 11, 2019 at 7:40 PM
    Lifted blue limo
    Lifted blue limo [OP] My other car is a Hyundai
    Devin
    Oregon
    13’ nautical DLCB turd sport
    6” RC lift, 35” Ironman mts, 17” pro comp III’s
    Hey guys brand new member here super excited to join and share information and sweet rides
    anyways My question is what are your opinions on gearing ratios?
    Just mounted 35” tires and here soon I’m headed to a diff shop. Unfortunately I’m between a rock and a hard place figuring 4.56 or 4.88 gears.
    I do the occasional off roading but not so much crawling. less often than not I need to tow a boat/trailer etc. she mostly sees pavement.
    (I know this is a common thread but can’t find a straight forward answer)
    leaning towards 4.56 but keep hearing to go 4.88
    pros?
    Cons?
    Any information and opinions would help greatly
  2. Dec 11, 2019 at 7:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are you an Auto or Manual?
  3. Dec 11, 2019 at 8:08 PM
    Lifted blue limo
    Devin
    Oregon
    Sorry auto tranny
  4. Dec 11, 2019 at 8:21 PM
    TnShooter
    Deogee
    STOCK
  5. Dec 11, 2019 at 8:50 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    What gear do you have now, what trans, what size tires did you start with? A lot to figure out. If you went up from a 30.5" tire to a 35" tire, if you have a 4.10 & go to a 4.56, you probably won't be back to where you were with the orig. tires. Google West coast differentials calculators, they have a calculator, put in your tire size, gear ratio, & mph. & it will calculate you your rpm. figure what rpm. you ran with orig tires, then what rpm. you run with new tires at same speed. Then put in different gear ratios to see what you will need to get you back to where you started, then go from there. The calculator is a great help.
  6. Dec 11, 2019 at 9:25 PM
    Lifted blue limo
    Devin
    Oregon
    I looked it up and the closest to stock was 4.56 if I calculated it correctly.. I keep reading that 4.88 is everyone’s go to but the high rpms at highway speeds are deterring me from it. Not to mention Configuring hills, wind, added weight (passengers, gear, occasional boat/trailer, etc.
  7. Dec 11, 2019 at 10:38 PM
    Lifted blue limo
    Devin
    Oregon
    That’s true 4.88 may pick up the added weight compared to 4.56 but the majority of my time driving is spent driving it to work and sometimes hitting the dirt roads as rarely towing or hauling material from the local Home Depot.
    I think 5.29 is out of my league. Seems a bit overkill for what I’ll be doing with her.
  8. Dec 11, 2019 at 10:39 PM
    Lifted blue limo
    Devin
    Oregon
    Every time you reply I just read it in bubbles’ voice.
    gets me every time
    Johnnyk33, Beretta4x4 and whatstcp like this.
  9. Dec 12, 2019 at 2:33 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Nothing to add but here for pics of tires and lift info.
    knottyrope likes this.
  10. Dec 16, 2019 at 8:01 PM
    Lifted blue limo
    Devin
    Oregon
    Leaning more towards 4.88 I think. Just because I want to be prepared for tire weight and have that little extra power for weight like hauling family and towing.
    bbaggett and whatstcp like this.
  11. Dec 16, 2019 at 10:31 PM
    bbaggett
    bbaggett Well-Known Member
    Trophy Club, TX
    2013 Tacoma Limited DCSB 4x4
    6" Rough Country lift, 295/65R18 Duratracs
    The debate of 5.29's are for 3rd gen since it has 6th gear. For 2nd gen, 4.88 is max with 5 gears.
    Since you have 35'" tires, either 4.56 or 4.88. If you tow, I think 4.88 would be fine. I'm rocking 33.1" tires and 4.56 seems "stock" which is what style I was going for.
