Gear shift indicator lamp
Discussion in '1st Gen. Tacomas (1995-2004)' started by jessehh, Dec 1, 2010.
  1. Dec 1, 2010 at 10:23 PM
    jessehh
    jessehh [OP] New Member
    99 toyota tacoma prerunner
    I have a toyota tacoma 1999 pre-runner. v-6, 2WD
    The light bulb recently burned out and I just need to know how difficult if any is to change this light bulb? I have looked at other similar posts but my truck does not match the exact description of the newer trucks listed. I am not referring to the dash lamps but the center console indicator lamp
    Truck has a center console gear shifter where the bulb is located.
    any suggestions. Thanks!
    I don't see this mentioned in the manual
  2. Dec 2, 2010 at 7:08 AM
    clarkie152
    clarkie152 Well-Known Member
    MA
    13 MGM Tacoma DCSB
    None, yet
    i replaced mine recently. the bulb is pretty expensive at the stealership (5 bucks for a bulb that is the size of a pebble. while i did it, i took out my whole center console and replaced the cup holder grips while the console was apart.
    first, i beleive there are 2 bolts in the box that you need to take out. theres also some screws on the side. then move to the front seat and you will ssee some screws there and take those out and it all will come out except for your gear shifter
    i never was able to take out the gear shifter, because the 4wd shifter. BUT i found the only wire under there and twisted it and it came out. replaced it. and put it all back together. It will take about an hour.
    i have an 03, but maybe you can use this as a basis
  3. Dec 2, 2010 at 8:41 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I replaced mine not hard to do, take the old bulb with you, if you don't go to the dealer for comparision, I found one at the local Menards 2 for $1.98.
  4. Dec 5, 2010 at 9:27 PM
    jessehh
    Thank you for this valuable information. I will keep all steps in mind once i get ready to tackle this job.
  5. Dec 5, 2010 at 9:30 PM
    jessehh
    thank you for your reply, I originally thought that removing the shifter was necessary to access the bulb. Now I have a better understanding and hope not to encounter any difficulties.
  6. Dec 5, 2010 at 9:33 PM
    clarkie152
    MA
    13 MGM Tacoma DCSB
    None, yet
    Basically, you are taking out the whole center portion. PM me if you need any assistance :)
  7. Dec 5, 2010 at 9:36 PM
    jessehh
    do you know the part number. I was unable to locate it online. Thanks!
  8. Dec 6, 2010 at 7:24 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Didn't buy it at the dealer.
  9. Dec 6, 2010 at 8:25 PM
    clarkie152
    MA
    13 MGM Tacoma DCSB
    None, yet
