Gear shift moving during acceleration,
Discussion in '1st Gen. Tacomas (1995-2004)' started by jt0102, Sep 4, 2014.
  1. Sep 4, 2014 at 10:33 AM
    jt0102
    jt0102 [OP] New Member
    Nashville
    01 PreRunner V-6, TRD
    None
    I have a 2001 RWD TRD with E-Locker, V6, AT. 95k miles. I am noticing during acceleration the gear shifter is moving or leaning back. This is something you can see while driving and feel by resting a hand on it. It hasnt come out of Drive ever. Sometimes on braking I will notice move slightly forward.
    Not sure if this is related but at highway speeds 67-75, the truck ride changes from smooth to really rough. The gear shifter, seats, steering wheel, all have significant vibration. Tires have been aligned, rotated, and balanced.
    Any thoughts on either? My concern is that something major is "loose" but I have no mechanical experience with this truck. Owned it for about a year and have had this problem the entire time.
    Thanks!
  2. Sep 4, 2014 at 10:39 AM
    muddog67
    muddog67 Well-Known Member
    That is normal , I have an automatic and it does the same thing very slightly . There is allot of torque moving through the trans when you accelerate and when you release the gas peddle the torque dissipates from the transmission and or transmission and transfer case
  3. Sep 4, 2014 at 10:53 AM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    The shifter "floats" so it's normal for it to move around while driving. The vibration might be your wheel bearings going bad though.
  4. Sep 4, 2014 at 11:03 AM
    jt0102
    Nashville
    None
    Thanks for the notes....96k miles and I have not changed them. Any recommendations?
  5. Sep 4, 2014 at 11:59 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    This is not normal. I have a 4x4 with AT, and its smooth as silk in all speeds. I'd have your motor mounts and u-joints checked out.
  6. Sep 4, 2014 at 1:48 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    +1
    Also check the Carrier Bearing between the drive shafts.
