Gear swap with bigger tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Knapin15, Dec 6, 2024.
  1. Dec 6, 2024 at 5:02 PM
    Knapin15
    Knapin15 [OP] New Member
    Has anyone ever swapped ring and pinion gear with bigger tires? If so did you see a change in power or fuel mileage?
    Ricardo13x likes this.
  2. Dec 6, 2024 at 6:18 PM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    Lots of people have but HOW big of tires are you talking? 35s? 37s? and what motor/trans in your truck?
  3. Dec 6, 2024 at 6:38 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    I believe you’re the first one with that idea. Let me do a little bit of research just to check if anyone has asked the question on this forum or online. Keep you posted man.
    TheWildMan, winkel and ZColorado like this.
  4. Dec 7, 2024 at 4:42 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    How much bigger? If you don't go over 33" the stock gears will be fine for most people.
  5. Dec 7, 2024 at 5:10 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yes.
  6. Dec 7, 2024 at 6:21 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    A cornerstone of offroad modification across all brands is re-gearing... try to ask a better question.
    Most toyota folks like ECGS since our third members are removable and you can ship them.
  7. Dec 7, 2024 at 6:01 PM
    TacoTuesday1
    FL
    this has never been done before.
    Ricardo13x[QUOTED] and winkel like this.
  8. Dec 7, 2024 at 8:59 PM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Well?!? Whatd you find out?!?! We're all waiting!
    Ricardo13x[QUOTED] likes this.
  9. Dec 7, 2024 at 9:12 PM
    High Desert Taco
    High Desert Taco Well-Known Member
    Wyoming
    2012 Pyrite DCLB
    I hope your research goes well, but really you should look in any of the tire size threads lots of people record their recipe and experience well.
    I went to 4.56 to run 33s it kept my acceleration good and speedometer accurate and met my need. The physics is pretty straightforward though. Do the math and find out what works for the tire size you are thinking. There is no world in which this type of mod results in better mileage.
    ZColorado likes this.
  10. Dec 8, 2024 at 11:04 AM
    Ricardo13x
    Upland, CA.
    Btw I’m
    oh crap forgot to mentioned that I found out that I did 4.56’s for 35”s
  11. Dec 8, 2024 at 11:20 AM
    2012Taco
    2012Taco Well-Known Member
    NJ
    '12 DCLB TRD
    OME 886's & Dakar's & LR UCA's, LT265/75 Duratrac's on Countersteer Offroads, 100RCC, ARB 50 fridge/freezer, ARB bullbar w/ Warn 9.5xps, dual battery setup, on board air and water, PrInSu topper rack carrying the gear and more to come!
    I tried swapping my ring and pinion gear with bigger tires but now my differential doesn't work anywhere near as well. Also, the ring and pinion swap was a big downgrade in grip and ride quality compared to when I was rolling on rubber.
