gear swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sooner, Jun 5, 2011.
  1. Jun 5, 2011 at 7:20 AM
    sooner
    sooner [OP] Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    has anyone installed the 4.56 gears on 2011 with 6-inch lift?and did your mileage or power come back from the swap.
  2. Jun 5, 2011 at 12:28 PM
    Sprink669
    Sprink669 Well-Known Member
    I would like to know this too. With my OME kit 886 with a ARB bumper and winch and running 285-75-16/s on the freeway I get about 16-17 and in the city it is about 14.
  3. Jun 5, 2011 at 12:31 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    may not help much, but im runnin 4.88s with 33s on a 4 cyl. The power increased dramatically. The intown mpg increased almost 5 mpg and the hwy mpg increased about 3 mpg.
  4. Jun 5, 2011 at 2:03 PM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    Im hopeing to do eather 430s or 456s in the future. I like running 285s. 373s are just to high for my liking.
  5. Jun 5, 2011 at 6:28 PM
    trot
    trot Dang.
    Aberdeen Proving Ground
    18 SW TRD OR DCSB P&T
    just a word of caution for folks, spend some time on your favorite gear calculators and try to get back as close to stock as you can, unless your truck is primarily for off road.
    i went too tall with my last 4x4 (4.56:1 and 32" BFG MTs) on a Cherokee Classic (XJ)
    this was the primary factor in my mileage dropping way off on the highway (other factors like weight, mud tires, blah blah blah) but the tall gears were a dream on the trail.... i got to the point of poor returns for the $$ pretty quick since going to 35" tires would have called for a front axle swap (that particular vehicle has a D35 front axle weak point, and the rear axles weren't all that great, but mine had the 8.25)
    doing gears gets real expensive, but it's worth it if you get it set up right, IMHO
  6. Jun 8, 2011 at 12:07 AM
    sooner
    TX
    2011-4X4-LONGBED
    the only people that are going to have a gear for a 2011 is yukon.they said the 4.56 would be ready in a month or so.im not going to run 35s so this is the only option for a 2011 with the smaller clamshell in the new front diff.
