Gear whine after diff fluid change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by el_smurfo, Feb 19, 2025.
  1. Feb 22, 2025 at 9:43 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Yes, I have a 2011 4x4 trd OR with the Elocker and Mech LSD carrier, and a 2009 2wd OR with the same.
  2. Feb 22, 2025 at 9:44 AM
    SoCaltaco65
    Nope, when I regeared it, it was the same as my 4x4, keep in mind I bought the truck used so it could be possible it was added.
  3. Feb 22, 2025 at 9:59 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Both of those trucks have the electronic locker and “simulated LSD” that uses the brakes to mimic a mechanical limited slip.
  4. Feb 22, 2025 at 10:37 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    Prerunner. My 05 has locking rear differential.
  5. Feb 22, 2025 at 10:50 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yeah, I don't think we are saying the same thing. A mechanical LSD has clutches that allow a limited amount of slip and sends power to the wheel that has traction. It's actually in the name - Limited Slip Differential. You don't have those clutches if you have a locker. Without the locker on, you have an open diff, but it can simulate the behavior of an LSD electronically by applying brakes to the wheel that is spinning, sending power to the other side. That's electronic LSD, not mechanical LSD.
    A mechanical LSD with clutches requires friction modifier. It comes in a tube. It is not already added to gear oil. Gear oil that says it is recommended/suitable for LSD diffs isn't saying it has friction modifier added, just that you can use it in a LSD. But you should add friction modifier.
    Friction modifier is not needed on an open diff that has a locker or simulates an LSD by applying the brakes.
    Sharpish likes this.
  6. Feb 24, 2025 at 8:05 AM
    el_smurfo
    el_smurfo [OP] Well-Known Member
    In 07, the Sport came with the LSD and the OR with the e-locker. The 2WD OR was the PreRunner. There was no brake style LSD AFAIK and it's obvious I don't have it trying to get out of my gravel parking spot.
  7. Mar 12, 2025 at 6:23 PM
    jbolts
    jbolts Active Member
    john
    2008 Tacoma TRD
    E-Locker and lsd are not one and the same or interchangeable afaik.
    LSD is 100% mechanical whereas E-locker is electronically actuated.
    Although not 100% accurate the door sticker code should let you know what you have.
    You get the axle code off the inside door panel- the last letter in the code tells you whether it is e-locker, open, or LS. A=open, B=e-locker, C=LS
    In my case A04C the C means I have a LSD.
    I cant imagine how a LSD would behave if swapped in a truck with an open diff with brake actuated traction control but I doubt it would be a good thing.
