Gear Whine after regearing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoman21, Oct 20, 2020.
  1. Oct 20, 2020 at 4:54 PM
    Tacoman21
    Tacoman21 [OP] Well-Known Member
    Bob
    2020 Silver TRD offroad 4x4 DCLB
    3" lift with KMC wheels 285/70/17 4.88 Nitro gears
    I know the gear whine has been beat to death but not with the Regeared trucks.
    I had 4.88s done on 9/5 and have had a high pitched whine from 40mph all the way down on Decel.
    It's not by any means loud you have to have the radio off and listen for it. Nitro acknowledges the fact these Tacomas are prone for gear whine.
    I'm not to concerned at this point. I've got almost 1000 miles on my gears and no change.
    Anybody else have THE WHINE after gearing? And what sound at what speed?
    wilcam47 likes this.
  2. Oct 20, 2020 at 6:37 PM
    Tacoman21
    Bob
    What no Nitro regear whiners?
    Rockefelluh likes this.
  3. Oct 20, 2020 at 7:20 PM
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    I have it, on two sets of gears. The first set was unbearable. The second set is tolerable and not much worse than the stock gear whine.
  4. Oct 20, 2020 at 7:22 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Is it the millennial gear set?
  5. Oct 20, 2020 at 7:27 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Somebody was lazy and didn’t change the pinion bearing
    abodyjoe likes this.
  6. Oct 20, 2020 at 7:57 PM
    Tacoman21
    Bob
    Who regeared you OP and did you get the specs from whoever regeared it like backlash?[/QUOTE]
    Martin from Mobile gear installers. He's Miguels brother from Premier west gears. He's done a ton of Tacomas. Just like Premier they don't use a dial indicator they do it from feel. I don't agree with t at all but the pattern was perfect. He told me he guaranteed the backlash was 6 thousands and the preload was 15 pounds. Like I said the pattern was spot on perfect.
  7. Oct 20, 2020 at 7:59 PM
    Tacoman21
    Bob
    Pinion bearings had 500 miles on them. Trucks brand new
  8. Oct 20, 2020 at 8:19 PM
    Tacoman21
    Bob
    Absolutely. The guys been doing gears for over 25 years. I've been wrenching for over 25 years I just don't do transmissions and gears. He had me spin the yoke after he did and it had enough tension but why not take 5 minutes and check with a torque meter. I questioned him but he had no doubt it was right and again the gear pattern was dead on. The noise is faint just when coasting as soon as it hits 38 mph it starts until I stop or hit the gas. Nitro gears in Toyotas are known to make noise, Hell stock gears in these trucks do.
    SR-71A and whatstcp[QUOTED] like this.
  9. Oct 20, 2020 at 8:44 PM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    Then the bearings are moving around on the pinion shaft because the preload is incorrect...the math don’t lie only people do.
    SandyTaco4x4, Hobbs and stu8319 like this.
  10. Oct 20, 2020 at 8:53 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Is that the same shop that just did a group buy in SoCal?
    whatstcp likes this.
  11. Oct 20, 2020 at 9:08 PM
    Tacoman21
    Bob
    Premier west is the group buy, Miguel. I used his brother Martin from Mobile gear installers. Both shops are run the same.
  12. Oct 20, 2020 at 9:13 PM
    therealprotaco
    Gilbert, AZ
    Some people do setup by feel. The guy who did the rear end on my stock samurai axles did it by feel. Was perfect on many many hardcore trail rides. My taco has been set up twice with all the precision equipment twice. It whined both times. All new bearings, new gears, setup is good. I actually watched and hung out in the shop the second time. He did it right. Nitro is fairly well known for whine. If I did it again I’d get a set from Yukon.
    n2xlr8n and Rockefelluh like this.
  13. Oct 20, 2020 at 9:27 PM
    T4RFTMFW
    Well, there were multiple issues with the other shop, and you’re on your second set of gears (assumedly) by this company?
  14. Oct 20, 2020 at 9:29 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    You sound like you are defending his whine now !
    FredRed315, Mark77 and whatstcp like this.
  15. Oct 20, 2020 at 9:34 PM
    ian rogers
    ian rogers Well-Known Member
    Ian
    Sf Bay Area
    69 fj40, 2019 OR manual
    Locked Sliders Roll cage H41
    I set the backlash in my fj40 by feel when I installed my arb lockers.
  16. Oct 20, 2020 at 9:37 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    OP, I’m assuming you’ve read all the threads on regear. As you know it is pretty common on nitro Gears. Although less so for 4.88.
    I have 5.29. Gear whine constant at 60-63 mph, and somewhere in the 40-50 mph range on deceleration.
    therealprotaco likes this.
  17. Oct 20, 2020 at 9:43 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    helix66 and ktbell444 like this.
  18. Oct 21, 2020 at 1:23 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Set backlash by feel. And people wonder why the differential whines.
    If it isn’t already too late, find a shop that does it correctly. It really is cheaper to spend more and do it right than do it twice.
  19. Oct 21, 2020 at 6:52 AM
    Tacoman21
    Bob
    Who said I was on my second set of gears?
    SR-71A likes this.
  20. Oct 21, 2020 at 7:00 AM
    Tacoman21
    Bob
    Not at all. I am not sure the whine is because of him that's why I started this thread.
    the guy does the gears for most of the shops in So cal. 4WDparts, rebel off road.
    I don't doubt his talent just his means of install. I watched the whole process and expected to see a dial indicator for backlash and a pinion preload torque meter. The guy has done hundreds of these Tacoma gears with no complaints that I could find. Well respected by all the local shops.
    My point of this thread is to see how common it is for Nitro gears to whine.
    SR-71A likes this.
