Gear Whine after regearing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoman21, Oct 20, 2020.
  1. Sep 15, 2023 at 8:05 PM
    #181
    sturdi
    sturdi Member
    Peter
    17 DCSB Off Road 6MT
    2017 6MT with 125k miles
    450 miles in with 5.29 gears. Got them assembled by ecgs and installed by a local 4x4 shop.
    I have not done much driving over 60mph per the break in period, but I was driving interstate tonight. I got a noticeable whine at 70mph. Only under throttle. When I let off throttle, it stopped.
    the sound is similar to a howling roof rack (been there before), but I have not changed anything on my roof in quite a while. Also, the noise stopping when I let off the throttle makes me think it’s not aero related.
    So my question - if ECGS assembled them and the local shop installed them, who should I call first on this? I’m not as schooled as some of y’all in the set up tolerances, but am I right that all of that would have been done by ECGS in the shop?
  2. Sep 15, 2023 at 8:11 PM
    #182
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    What size tires? My 6MT on 5.29s ran on the stock tires for a bit and right at 70 I got a ringing noise, kind of like a tea kettle noise. Only in 6th and 5th, completely gone in 4th. Does yours do it in 4th too? Mine is also only on the throttle, I think it’s just the gear teeth spinning so fast in 5th and 6th since they’re ODs.
  3. Sep 15, 2023 at 8:25 PM
    #183
    sturdi
    sturdi Member
    Peter
    Good questions
    33” all terrains
    Yes it happened in 6th
    I will check 5th tomorrow.
    I was/am nervous to get to 70mph in 4th during the break in period. Pretty high rpm with these new gears at that speed.
    overall the regear is sick and it makes the truck drive exactly how I’ve always wanted. I was 100% positive about it until this whine.
    I’ll also get up above 70mph tomorrow to see if it quits.
  4. Sep 15, 2023 at 8:31 PM
    #184
    BLtheP
    Plano, TX
    The gears are spinning fast at 70 no matter what gear trans is in, so you’re safe to test it out. Your tach will be around 3800 or so at 70.
    Agreed, regear is awesome on the manual transmission. 5.29 on 32’s and love it.
