Gearing 4cyl auto... need answers!!
Discussion in '4 Cylinder' started by eclipse22, Jul 29, 2013.
  1. Jul 29, 2013 at 6:48 PM
    eclipse22
    eclipse22 [OP] Well-Known Member
    Marcin
    I looked all over the forum and checked out 11 pages of threads and cannot get a concrete answer on regearing my 2006 Tacoma 2wd 2.7L auto access cab. I know i have 3.58 gears and want to upgrade to 4.10. But do the 4.0L V6 have the same rear end. A local wrecker has about 7 newer tacomas and I need to know what I am looking for and what truck I should inquire about. I would buy the whole pumpkin which would be the easiest bet. help!
  2. Jul 29, 2013 at 7:20 PM
    eclipse22
    Marcin
    Do i have a 7.5" rear?
  3. Jul 29, 2013 at 7:23 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    I am 90% sure they are the same rear end. the only way you get a different bolt pattern is if it has a electronic locker.
    and it is a 8.4 inch ring gear...
  4. Jul 29, 2013 at 7:25 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    2006+ has 2 different carriers, 8" and 8.4". as I understand it, the 8.4 is on the TRD sport. I don't want to commit to saying you have the 8" though. Keep in mind if you get the right size its a carrier swap, all good. If you try the whole axle, your 2wd is spring under, ours are spring over. Sorry I couldn't nail it more for you.
  5. Jul 29, 2013 at 7:26 PM
    blake5995
    Blake
    Truckee, CA
    isnt the 8" only in elocker housings and the other non locker trucks come with 8.4"
  6. Jul 29, 2013 at 7:27 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    I think only the 2nd gen 4cyl prerunner & 4wd have 4.10 gears
  7. Jul 29, 2013 at 7:27 PM
    blake5995
    Blake
    Truckee, CA
    and a 4.0 v6 wont have the gears you want unless it is aftermarket...
  8. Jul 29, 2013 at 7:28 PM
    Tacoyota
    08 4wd
    That's where I start getting lost and take a drink. I bet you are right though.
  9. Jul 29, 2013 at 7:30 PM
    blake5995
    Blake
    Truckee, CA
    now you have
    2wd 5 lug?
    pre runner
    4wd
    right? i dont know anything about the 2wd xrunner i think it is called
  10. Jul 29, 2013 at 7:40 PM
    Tacoyota
    08 4wd
    sounds right on the lugs.
    It got so strange I had a reputable shop do my gear swap to 4.56. They got delayed getting the wrong parts sent....or did they order wrong. Guaranteed for a year so its all good.
    For OP http://www.tacomaworld.com/forum/2nd-gen-tacomas/64621-rear-locker-swap-trd-non-trd-prerunner-2.html
    looks like 7.5" is likely. see the 28th post.
  11. Jul 29, 2013 at 7:42 PM
    blake5995
    Blake
    Truckee, CA
  12. Jul 29, 2013 at 7:44 PM
    Tacoyota
    08 4wd
    No I have the 4wd. OP has the 2wd. :eek:
  13. Jul 29, 2013 at 7:44 PM
    blake5995
    Blake
    Truckee, CA
    7.5 inch ring gear is a IFS gear. i think you need 8.4 inch gears...
  14. Jul 29, 2013 at 7:45 PM
    blake5995
    Blake
    Truckee, CA
    i thought you were OP... 7.5 is the front IFS gear for a 4wd truck. 8.4 inch is for the year of OPs truck final answer lol
    OP you need a 8.4 inch ring gear
  15. Jul 29, 2013 at 7:46 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    All the trucks have an 8.4" rear end unless they have the E locker 3rd, which is an 8". You will know if it has the e locker actuator because it will be on the front side of the 3rd member. Clarify it?
    second, do you have a 2.7 pre runner or base? (dont know what power plant options go with what on 2nd gens, but it doesen't matter)
    why do you want to regear? For the price of regearing (its not cheap at all) it does not seem worth it to just go to factory 4.10s. Might as well go 4.56 if you want to get bigger tires.
  16. Jul 29, 2013 at 7:46 PM
    Tacoyota
    08 4wd
    Not sure if this direction is helping or hurting, the post has him saying 5 lugs are 7.5"...... honestly I'm looking for a solid answer.
    rossk35 [​IMG]
    Do Work Son!
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Gender: Male
    07 TRD Sport Supercharged2007 Double Cab Automatic 4.0
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Quote:
    Originally Posted by solus694 [​IMG]
    what about the LSD from a sport? would I need the whole axle too?
    I answered this question in my above post with the pictures. If you don't have a locker you can swap just the 3rd members. Because every other tacoma that is 6lug all have the 8.4" rear end.
    Trd offroad= 8" axle. You can't swap anything if you have this axle.
    Trd Sport/Non TRD all have a 8.4" axle whether you have a lsd or an open diff. The xrunner also has this axle but is 5lug.
    The axle shafts are all the same for the 6lug.
    5lug 4cyl have a 7.5" axle.
    __________________
    [​IMG] [​IMG]
  17. Jul 29, 2013 at 8:11 PM
    eclipse22
    Marcin
    wow you guys work fast! The local wrecker had a 4.10 3rd member with e locker for 300, and i hate the one wheel peel!
  18. Jul 29, 2013 at 8:14 PM
    eclipse22
    Marcin
    ** my truck is a 2wd 5 lug sr5 auto by the way
  19. Jul 29, 2013 at 8:44 PM
    eclipse22
    Marcin
    so should I go for the purchase because they dont do cash refunds just in store credit
  20. Jul 29, 2013 at 8:54 PM
    blake5995
    Blake
    Truckee, CA
    that is a 8 inch ring gear and will not fit any other housing than a elocker housing SO DO NOT PURCHASE IT. You need a 8.4 inch 3rd member
