Gearing Down do or Dont?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bromagen25, Apr 5, 2011.
  1. Apr 5, 2011 at 3:43 PM
    bromagen25
    bromagen25 [OP] Well-Known Member
    Stock
    Rear Breather
    I have a 2.7 manual and was just wondering what every one thanks on the subject of ( Down Shifting )
    I have heard that it is not good for your transmission and hard on your engine but i have also heard it is good to but hurts your mpg at the same time because of the rpm or something.
    So i would like to know what you guys thank about it is it a do or a dont?
    also How strong is the transmission in the 2.7 stick?
  2. Apr 5, 2011 at 3:45 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    Are you talking about down shifting or re-gearing to a higher gear ratio?
  3. Apr 5, 2011 at 3:50 PM
    bromagen25
    Stock
    Rear Breather
    down shifting sorry about that
  4. Apr 5, 2011 at 3:51 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Gearing down from say 4.11 to say 3.73 in the axle , id say i wouldnt
    I think you mean downshifting a gear though , like 4th to 3rd. And to that yea , shift down if you need to.
    Dont do this though..... 4000rpm in 4th and go into 3rd.more likely you wont go from 3000rpm in 4th and downshift to 3rd even, but that area gets grey.Its in your owner manual if you want the EXACT downshift speeds.
  5. Apr 5, 2011 at 3:52 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    Sometimes I downshift and some I don't.Depends on the situation.Dont see any difference om mpg.
  6. Apr 5, 2011 at 3:53 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    Nothing wrong with down shifting. I wouldnt do it all the time to slow yourself down though.
  7. Apr 5, 2011 at 3:54 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    The truck can definitely handle it. Just dont do it all the time. I was messing aroung racing the other day and I down shitfted to just below the redline. I've done this multiple time.
  8. Apr 5, 2011 at 3:56 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    Its how I was taught to drive a stick. Downshift to help slow you down. That being said don't shift into 2nd if you're going 60mph.
  9. Apr 5, 2011 at 4:35 PM
    bromagen25
    Stock
    Rear Breather
    thanks for your input.
