Gearing on front differential.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IowaDucknDeer, Feb 8, 2020.
  1. Feb 8, 2020 at 3:18 PM
    IowaDucknDeer
    IowaDucknDeer [OP] Member
    Curt
    2007 tacoma
    Looking for some help. I’m thinking that the shop may have put in the wrong differential. According to dealer parts and the door jamb plate (A04A) it should be the 8”, 3.73 (3-727) open.
    I’m trying to decipher the only tag on the new diff.
    The issue I’m having is that the transmission just seem to be wound up when going down the road.
    Thanks
  2. Feb 8, 2020 at 7:35 PM
    Pigpen
    Dan
    Northwest Montana
    If you're not in four wheel drive, the gearing in the front diff won't affect anything.
    whatstcp likes this.
  3. Feb 8, 2020 at 7:44 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Maybe @Muddinfun can explain how to figure this out by
    Tire/driveshaft ratio.
    I know you can get the rear diff ratio this way.
    You should also be able to do it with the front as well.
    But I think there are a few more steps.
    Maybe all 4 of wheels off ground in Neutral and turning the front tires while in 4WD.
    Again, Muddin probably knows how to do it.
    Maybe he’ll jump in with a good idea.
  4. Feb 8, 2020 at 7:48 PM
    Muddinfun
    Muddinfun Well-Known Member
    The front ratio doesn't matter when in 2WD. If they put the wrong ratio in and you put it in 4WD, the truck won't move easily, since the front and rear tires will be working against each other.
    whatstcp and TnShooter like this.
  5. Feb 8, 2020 at 8:18 PM
    Pigpen
    Dan
    Northwest Montana
    If the tranny sounds wound up, it may be low on fluid.
  6. Feb 8, 2020 at 8:25 PM
    Muddinfun
    Reading the OPs 2 other posts, there's "transfer case fluid" all over the bottom of the truck. It's going to be interesting to see what the shop has to say.
    TnShooter and whatstcp like this.
  7. Feb 8, 2020 at 8:33 PM
    TnShooter
    Deogee
    STOCK
    I’d be pretty adamant that hat it is covered under the 12m/12k mile warranty.
    Although I am curious as to why it need a front diff?
    Was it victim of trail damage or ‘normal’ failure?
  8. Feb 8, 2020 at 10:49 PM
    IowaDucknDeer
    Curt
    2007 tacoma
    It was most definitely driver failure. My daughter drove it for a few bad snow storms and left it in 4wd on hardball and at highway speed to and from town. An expensive learning curve on her part. With the complete shoulder reconstruction just a few weeks ago there was no way I could do the work myself.
    I know many will say not to use the dealership mechanics but the price was the same. I went with a local shop with a good reputation, so I was told.
    TnShooter[QUOTED] likes this.
  9. Feb 9, 2020 at 5:15 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Most of the failures I've seen involving running on pavement in 4X4 were with the transfer case. I've never known of the front diff failing when doing that. I've read of driveshafts and U-Joints breaking, but not the front diff.
  10. Feb 9, 2020 at 7:35 PM
    IowaDucknDeer
    Curt
    2007 tacoma
    Thank you. I’ll keep an eye on it as well and have it checked.
    TnShooter likes this.
  11. Feb 10, 2020 at 12:28 PM
    Muddinfun
