Gearing Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Northof62, Aug 10, 2015.
  1. Aug 10, 2015 at 5:23 PM
    Northof62
    Northof62 [OP] Active Member
    Alaska
    2015 4x4 AC 6cl
    Toytec Boss 3" LR UCA 265/75 Toyo AT2 Blue Seas Fuse Panel Rear Diff Breather Mod After Market Stereo
    When I installed my 3" lift and 265/75 tires I told myself I would eventually re gear when I was ready to move up to something like a 285/75 and add some armor. Well that time has come, I was going to send my 3rds in for a re gear and have a ARB locker installed. I was trying to decide between 4:56 and 4:88 when I realized my truck came with 4:56.
    So the question is should I just keep the 4:56? After the new tires I experienced a big MPG loss but I haven't noticed much power loss and the tranny doesn't hunt for gears.
    I have the V6 and non E locker. The truck sees a lot of highway miles at 65mph but I also off road a lot. Any suggestions would be much appreciated.
  2. Aug 10, 2015 at 5:24 PM
    la0d0g
    running for the hills
    For crawling not hauling
    How did you get 4.56s in there. Someone mod it before selling it to you?
  3. Aug 10, 2015 at 5:26 PM
    Northof62
    Alaska
    2015 4x4 AC 6cl
    Nope. It came that way. At least according to the VIN sticker. I'm the original owner. I read somewhere that if it comes stock with 31" tires you get the 4:56.
  4. Aug 10, 2015 at 5:27 PM
    la0d0g
    Not sure where you read that but 3.73 is what a stock v6 comes with.
  5. Aug 10, 2015 at 5:28 PM
    Northof62
    Alaska
    2015 4x4 AC 6cl
  6. Aug 10, 2015 at 5:33 PM
    la0d0g
    Prerunner?
  7. Aug 10, 2015 at 5:35 PM
    Northof62
    Alaska
    2015 4x4 AC 6cl
    No, 4x4
  8. Aug 10, 2015 at 5:37 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I think 3.73 and 4.10's are the two choices your truck could have. Depending on 4 cyl or V6.
  9. Aug 10, 2015 at 5:37 PM
    la0d0g
    I'll let someone correct me but I'm almost positive a stock v6 4x4 comes with 3.73s. Mine did and that's why I went with 4.56s with 315s.
  10. Aug 10, 2015 at 5:38 PM
    deeezy
    Dana
    Hawaii
    My V6 4x4 had 3.73's.
  11. Aug 10, 2015 at 5:39 PM
    Northof62
    Alaska
    2015 4x4 AC 6cl
    Yeah, I'm not sure. I just know that my gear code is A04A. Every chart I've checked says that is 4:56. Maybe I have a rare gem:D
  12. Aug 10, 2015 at 5:41 PM
    slodc4
    slodc4 Conceal Carry
    Steven
    Winterville, NC
    Locked 17 trd sport
    What do you rev at 55mph on stock tires?
  13. Aug 10, 2015 at 5:56 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    I wish I had 4.56 stock! V6 is 3.73. I've been shopping used front carriers and they all are 3.73 or 4.10's.
  14. Aug 10, 2015 at 5:56 PM
    hilux30
    hilux30 Well-Known Member
    PEI
    '15 4Dr SB 6MT
    OTT tune 3 degree cam gear OME/Dobinson
    That's the ratio in direct drive 1:1, 4th in the A750 trans.. still has 3.73 in 5th/overdrive..
    So, technically you don't need 4.56s just keep it in 4th! ;)
    I'm doing that next couple weeks: 285/75s with 4.10s (from 3.73) .. on the highway plenty.. it should do..
  15. Aug 10, 2015 at 6:08 PM
    Northof62
    Alaska
    2015 4x4 AC 6cl
    I'm not sure, I took them off in the first week of owing the truck and put on 265/75R16. Now I get 1600
    Ohhhhhhh. Ok, thanks for clearing that up.
  16. Aug 10, 2015 at 6:30 PM
    hilux30
    PEI
    '15 4Dr SB 6MT
    yes, 1600RPM at 55 is 3.73... by the way 265/75-16 are actually almost the perfect size for a dead-on speedo.. 265/70-16s factory are 6% too small, but better in torque..
    And don't "lug" the engine too much, not healthy (now with slightly taller tires).. around town try to keep it in 4th 'till you go above 50MPH or highway.. especially if you got constant weight/load..
    slodc4 likes this.
  17. Aug 10, 2015 at 6:39 PM
    Northof62
    Alaska
    2015 4x4 AC 6cl
    Thanks Guys. I guess I'll have to buy some new gears after all.
  18. Aug 10, 2015 at 7:32 PM
    la0d0g
  19. Aug 10, 2015 at 10:32 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I run 265's for winter and 285's for summer and have never found any reason to regear, the 3.73's make for a nice all around gear for the v6.
    MPG's only differ about 1 between the two and the speedo is about the same.
    To me spending all that money for gears is a waste until you get over 35in tires..
    (but I could be wrong) "not"
  20. Aug 11, 2015 at 6:36 AM
    smd3
    smd3 Well-Known Member
    Is it flat where you are? I went to 265/75, and my truck feels like a dog. 'E' rated. We have a Lot of hills.
