Gearing Questions (V6 Auto)
Discussion in '1st Gen. Tacomas (1995-2004)' started by PanDa_, Mar 27, 2020.
  1. Mar 27, 2020 at 9:23 PM
    PanDa_
    PanDa_ [OP] Active Member
    Dylan
    Was wondering for re-gearing, would 4.30 or 4.56 be better? 265 - 285/75r16 Tires, tube front bumper, plate rear with swing out, and ifs and t-case skids. 4x4 v6 Auto, Ext cab. Was wondering, because I've seen a ton of threads for manual trans gearing, but not many for auto. Towing semi-often, along with pulling a camper trailer (probably around 1500-2000 Lbs) full time on a road trip in the future.
    Thx
  2. Mar 28, 2020 at 6:14 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    What is your current gear ratio?
  3. Mar 28, 2020 at 9:22 AM
    Boone Wesley
    Boone Wesley Well-Known Member
    Boone
    LA 818
    01 4D 4WD Limited
  4. Mar 28, 2020 at 11:55 AM
    PanDa_
    Dylan
    Not sure, I assume stock, just researching before I get one, to stock pile parts
  5. Mar 28, 2020 at 12:02 PM
    Boone Wesley
    Boone
    LA 818
    01 4D 4WD Limited
    You won't feel a 4.10 to 4.30 swap much, if at all, but 4.10 to 4.56 now we're talkin.
  6. Mar 28, 2020 at 12:12 PM
    PanDa_
    Dylan
    I've read that 4.56's make your rpm hella high when highway crusing, or is that just for manual? Truck will also be daily driver
  7. Mar 28, 2020 at 1:49 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    High rpm with low load is better than low rpm with high load.
    Digiratus and Sna like this.
  8. Mar 28, 2020 at 1:59 PM
    PanDa_
    Dylan
    Low load steering? Like easier to steer or something?
  9. Mar 28, 2020 at 2:02 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    Sorry, fat fingered the keys on my phone.
  10. Mar 28, 2020 at 2:05 PM
    PanDa_
    Dylan
    Ah ok, essentially re-gearing makes the load lower, so 4.56's would probably be the best option. Do you get a decent/more amount of torque back with re-gearing, or is it not really noticeable?
  11. Mar 28, 2020 at 3:00 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    since you are moving to larger tires, when you re-gear you bring that target rpm back in range for HP/TQ so it acts as it does now. if you just add larger tires you will notice "power loss" as it requires lower gear to maintain speed and will shift constantly trying to keep up.
  12. Mar 28, 2020 at 3:02 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    Maximo_23 likes this.
  13. Mar 28, 2020 at 3:11 PM
    PanDa_
    Dylan
    Think I'm going to go 4.56's, Thanks frizzman for the calculator, I actually used that yesterday before I posted here but I didn't notice the gear ratios at the bottom lmao
  14. Mar 28, 2020 at 3:18 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    you can use this to play around with different tire sizes and gear ratios.
    http://www.grimmjeeper.com/gears.html
    You can see what gearing will bring you back to stock with your tire size.
    Also consider if stock is good enough. I know my truck is pretty heavy and has a bunch of wind resistance due to the camper I built.
    I have 4.10 gears on 255 85 16 (33”) mud terrains. 4.56 will be lower than stock but I don’t think It’ll be sufficient so I’m going with 4.88’s.
    Sna likes this.
  15. Mar 29, 2020 at 7:25 PM
    PanDa_
    Dylan
    I thought about 4.88's too, but I think 4.56's might be a happy medium, we'll see eventually
    otis24 likes this.
  16. Mar 29, 2020 at 7:43 PM
    Rockymtntacoma
    Rockymtntacoma Well-Known Member
    Jake
    SLc,UT
    03 ext cab 4x4 v6 5 speed sr5
    Dual cases, triple sticks, 4.88’s, Harrop e-locked f/r, 35’s, boosted
    with the extra weight and 285’s, 4.88’s all the way!!!
  17. Mar 29, 2020 at 7:48 PM
    PanDa_
    Dylan
    Well, not a super amount of weight, just a tube front and rear bumpers, tube tire swingout tailgate (saw an epic one on here, cant remember from where though...), sliders, skids, some misc lights, and towing a RTT Trailer (maybe like 1300#'s fully loaded, maybe a tad more). :rofl:Think maybe might just get 4.56's, if I don't like em/need more power, I can sell/give them and get 4.88's. But I would think higher gearing -> higher rpm = Lower mpg, and I kinda wana keep it decent, since I will be going all over the u.s with it. But who knows
    otis24 likes this.
  18. Mar 29, 2020 at 10:57 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    IMO, 4.88s at the minimum with the auto and 33s. Especially if you are any heavier that stock. 70 mph with be 2500 rpm.
    Having said all that, sometimes I wish I had gone with 5.29s instead of the 4.88s.
  19. Mar 30, 2020 at 11:30 AM
    PanDa_
    Dylan
    Yeah, I have been looking a bit at the rpm's, and have also heard the v6's are rev-happy. 4.88's? Hmmm....How do you like the 4.88's with the auto?
  20. Mar 30, 2020 at 7:59 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    my 70 mph with 31's and 4.10 was around 2200, so I don't think you would be up in the 3's without shifting
