Gearing up for a 1350 mile road trip over the weekend
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004TacomaSR5, Jul 30, 2015.
  1. Jul 30, 2015 at 8:47 PM
    2004TacomaSR5
    2004TacomaSR5 [OP] Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    What all should I prepare for before embarking on a long drive like this? Be the furthest distance I've taken this truck in one stint since I've had it. Tires are fair with a brand new spare underneath, oil only has 3k on it, but is Pennzoil Platinum 5w30 synthetic so it's good for awhile yet I believe. Transmission fluid is good and tomorrow I will check the rear diff fluid and make sure it's good. Anything else I should check before we take off? The truck will be carrying 4 people and a trailer weighing about 1500# on the return trip so I don't want any problems if I can avoid them.
    Anyone with experience road tripping in these little things shed some insight for me please! Last cross country trip I embarked on was in a brand new at the time 2nd gen so I had no worries at all with that rig.
  2. Jul 30, 2015 at 9:21 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Tire pressures would be good to top off and make sure its running good! I drove mine for a little over 1000 miles in a day from GA to Neb with a trailer (2k) and full bed (300lbs?) without a problem at 215k
  3. Jul 31, 2015 at 12:13 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    When was the last time the transmission was serviced??
    Just take a nice slow trip coming home if you need to pull any passes take your time and don`t cook the transmission.
  4. Jul 31, 2015 at 12:41 AM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    check your coolant? Take some spare gas just incase? I usually keep a first aid kit, flashlights, bug spray, sun block, spare batteries, jumper cables, bear mace and straps behind or unDer my seats at all times. The bear mace is for hiking and I also keep it up front just incase I'm in a bad neighborhood lol.
  5. Jul 31, 2015 at 2:27 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Just check your tire pressure and fluids, do a walk around to check for leaks and go have fun. I do long road trips on a very regular basis. And eyeball your belts!
