gears for 07 taco
Discussion in 'Performance and Tuning' started by in2nite, May 2, 2008.
  1. May 2, 2008 at 9:25 PM
    in2nite
    in2nite [OP] Well-Known Member
    James
    SoCal.
    blk 07 prerunner
    Engage Offroad L/T front and rear, Kings and 50t pack, Hella 4000's, Pro Comp Wheels and tires
    Has anyone done a gear swap in there prerunner? If so can someone tell me what changed to... im not even sure what the stock gears r. Im looking for a bit more low end torque. Thanx...James:confused:
  2. May 3, 2008 at 5:39 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Pre-Runners have the same rearend gearing as the 4x4s which is 4.10. Base model trucks have 3.63, IIRC, which would give you better gas mileage. For more torque, you need to go in the other direction. However, you will have a lower top speed and worse gas mileage because you have to turn a higher RPM.
  3. May 3, 2008 at 8:33 PM
    in2nite
    James
    SoCal.
    blk 07 prerunner
    Thanx Jeremy... I figured on losing a little bit of everyhing and with rising gas prices may not be a good idea to change them right now.. James
  4. May 4, 2008 at 11:53 PM
    cmfranks
    cmfranks Well-Known Member
    Craig
    Austin,TX
    08 DC Pre-Runner 6in Pro Comp Lift
    BHLM, Pro Comp Skid Plate, AFE Drop in Air Filter, Tint, Pioneer AVH 4000 DVD,Polk Audio 6.5 components, Polk 6.5 co-ax's, Polk Audio 400.1 amp, Polk Audio 500.1 amp, (2) Polk Audio 10 in Momo subs, Mr Marv sub box, Sockmonkey decals, Redline Elite hood struts, Bak Flip tonneau cover, N-Fab Nerf bars, Painted Center Console & Window/Door Lock Panels Black, Amber LED Dome/Map Lights
    Actually the pre runners have a 3.73 gear ratio. Called toyota and they confirmed this. (give them you VIN #). I have a 6 inch lift w/ 305/65/17 and just installed 4.11's. I don't know if this is going to help much w/ my mpg yet but have noticed a huge diffrence with the performance. The take off as well as the hwy driving is much better.
    Hope this helps!!!!!
  5. May 5, 2008 at 12:47 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    My 07 4x4 has 3.73's in it. i think they're pretty common, so maybe 4.10's for the swap. It's gonna lower the MPG though.:cool:
  6. May 5, 2008 at 5:06 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Guess I should have been more specific.
    2.7L Base 5spd = 3.31
    2.7L Base Auto = 3.58
    2.7L 4x4/Pre-Runner 5spd = 4.10
    4.0L 4x4/Pre-Runner 6spd = 3.73
    4.0L 4x4/Pre-Runner Auto = 3.73
    4.0L X-Runner = 3.15
    Either way, it's listed on the Toyota website. Goto http://www.toyota.com/tacoma/specs.html and pick your exact model.
  7. May 6, 2008 at 11:24 AM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    Does the towing package affect the gear ratio?
  8. May 6, 2008 at 9:01 PM
    in2nite
    James
    SoCal.
    blk 07 prerunner
    so if I went to a 4.10 do u think I would lose a lot of miles on the tank...
  9. May 7, 2008 at 4:48 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Assuming my math is right, you would have to spin the engine 10% faster to cruise at the same speed. Say you usually cruise at 2500 on the freeway. Now you will be turning 2750 going the same speed as before. What that works out to in MPG is difficult to say without knowing other things. You could just generalize and assume that you'll loose 10% of what you're getting now.
