gears for rear differential
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rollacoasta15, Apr 17, 2011.
  1. Apr 17, 2011 at 9:52 PM
    rollacoasta15
    rollacoasta15 [OP] Well-Known Member
    Serge
    NOR CAL
    Stud
    lift and rims
    Hey guys, I was always interested about switching out gears in the rear differential to save gave and increase power. Does that really work or are the stock factory gears just fine. Please let me know what is the best set up and how effective would it be and of course the cost. Thanks in advance :)
  2. Apr 17, 2011 at 9:55 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Eastcoastgearsupply.com
  3. Apr 17, 2011 at 10:04 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    what size tires do you have?
    Whats the specs on your truck? SR5? TRD offroad? Auto, manual? Prerunner or 4x4? etc
  4. Apr 18, 2011 at 4:01 PM
    rollacoasta15
    Serge
    NOR CAL
    Stud
    lift and rims
    my truck is a trd offroad, sr5, 6 inch lift, supercharged, manual, 4x4. I was hoping to alternated between 33 inch tires (for highway) and 37 inch tires (for off road)
  5. Apr 18, 2011 at 4:21 PM
    08pretaco
    Oliver
    az
    Your going to have a hard time accomodating for both
  6. Apr 18, 2011 at 4:22 PM
    08pretaco
    Oliver
    az
    Your going to be extremely over geared geared for the 37 or way under geared geared for the 33, you going to have to settle for a medium, which you might not be happy with.
  7. Apr 18, 2011 at 4:24 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Fixed:cool: But this is true. Go 35s for a happy medium. Plus 37s are going to rub way too much to be useful off road. Unless you do long travel in the front and glass fenders allround like a guy on TTORA did.
  8. Apr 18, 2011 at 4:39 PM
    08pretaco
    Oliver
    az
    Thank you, I'm in class and on my phone so thanks for fixing it haha
    Actual i dais Oy right-hand just confusing. Your over geared when geared for the 37 while you run the 33 and under geared geared for the 33 running the 37. That's gotta make more sense I hut forgot to add a little info.
  9. Apr 18, 2011 at 4:40 PM
    S.B.
    Sean
    no prob. I got class in 10:(
  10. Apr 18, 2011 at 5:13 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    $2000 to swap front and rear gears +/-. so. at $4/gallon,thats500 gallons of gas you could buy instead, at say 15 mpg and go 7500 mi. bottom line is you cant really spend money on an offroader to make up for high gas prices.
    Focus more on combined trips, drive less, and working with what you have imo. Gearing to lower r.p.ms lower might not get you better mpg too.
    What if it gained you only +1 mpg, I doubt youll get 3mpg. If your RPM at 65 was say 3000 rpm now, then you have a chance to gain mpg, if its more like 2200 rpm now, I wouldnt be surprised if it didnt help any but went lower mpg.
