***GEARS GB!!!!***ENDED
Discussion in 'Automotive Group Buys' started by MTNHABITOVERLAND, Oct 10, 2018.
  1. Oct 12, 2018 at 7:34 AM
    #41
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Per the SDHQ site....
    REM POLISHING
    REM treatment results in a smoother surface. The end result is less friction, less heat, and less wear. Any machined part has high and low areas left over from machining, grinding, etc. Those high spots become the initial contact points which in turn can become localized hot spots. Those localized hot spots can take the temper out of the heat treated area of the surface and then become a pit. REM reduces that possibility.
    Other benefits include elimination of stress risers on the edge of parts and less friction on any metal on metal surfaces.
    tomz3rdtoy and The_Black_Pearl like this.
  2. Oct 12, 2018 at 8:12 AM
    #42
    HoglundOverland
    HoglundOverland Well-Known Member
    Ken
    2015 DCSB Silver Taco
    Volant CAI, CBI bumpers, skids and sliders.
    Fine, add REM polishing to mine, haha.
  3. Oct 12, 2018 at 8:29 AM
    #43
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    I mean, it's only money, right?
  4. Oct 12, 2018 at 8:52 AM
    #44
    Pureevil13
    Pureevil13 Active Member
    Lonnie
    Cary, Il
    17' Tacoma TRD Sport
    3" Fabtech lift w/UCA's Dirt Logic Coilovers with remote resi's SSO slimline front bumper with 20" light bar SmittyBuilt X20 synthetic rope winch Rigid mulicolor Ditch lights W/Rago Fab mounts JDM Hood Scoop Light bar RCI Offroad Sliders RCI full set of skids Morimoto HID conversion kit(Low Beam) Morimoto LED fog lights KB Voodoo 58" rack Smittybilt RTT Nitto Ridge Grapplers Custom Grill Window Tints Remote start Decal inserts for the tail gate, dash and door sills Interior LED lighting SPOD with custom switch plate
    In. B (4.56) + REM
    MTNHABITOVERLAND[OP] likes this.
  5. Oct 12, 2018 at 1:46 PM
    #45
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    2017 Barcelona Red Tacoma TRD Pro
  6. Oct 12, 2018 at 1:58 PM
    #46
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    Put me down for A - 4.88 Please and thank you, Nicole!
  7. Oct 12, 2018 at 2:01 PM
    #47
    MTNHABITOVERLAND
    MTNHABITOVERLAND [OP] Well-Known Member
    2016 Tacoma Camper Build Instagram: @mountainhabit
    Vagabond Outdoors Camper
    You got it brother!
    dlo13[QUOTED] likes this.
  8. Oct 12, 2018 at 3:54 PM
    #48
    The_Black_Pearl
    The_Black_Pearl IG: the_black_pearl_tacoma
    Colorado Springs, CO
    2013 All Black Tacoma Double Cab Long Bed
    Can my order be updated with REM as well?
  9. Oct 12, 2018 at 3:56 PM
    #49
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    So... no 1st gen love? :angrygirl:
  10. Oct 12, 2018 at 4:29 PM
    #50
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Update mine with REM please!
  11. Oct 12, 2018 at 5:00 PM
    #51
    MTNHABITOVERLAND
    Done:thumbsup:
  12. Oct 12, 2018 at 7:43 PM
    #52
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    Gears here! Get your gears here! Gears with REM here! Get you gears here!
    The_Black_Pearl likes this.
  13. Oct 12, 2018 at 7:47 PM
    #53
    Ayeele
    Ayeele Well-Known Member
    Houston, Tx
    18 TRD Pro, 04 DCSB 4x4
    Anyone can explain the rem? Doesnt the gears get a final polishing after break in anyways?
  14. Oct 12, 2018 at 7:55 PM
    #54
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    It's like this:
    https://youtu.be/T6ud6b1RIxE
    just doing a bit of research today I found what you just mentioned - REM shortcuts the break-in. I'm curious about other gains as well.
    Gmarq likes this.
  15. Oct 12, 2018 at 7:59 PM
    #55
    MTNHABITOVERLAND
    Post #42
    Sociopenguin likes this.
  16. Oct 12, 2018 at 8:56 PM
    #56
    sdfuller88
    sdfuller88 Well-Known Member
    Reno, NV
    In
    B-4.88
  17. Oct 12, 2018 at 11:10 PM
    #57
    TacosEveryday
    TacosEveryday New Member
    Peter
    San Diego
    2018 Cement TRD OR
    I’m in for A/4.88 non-polished. Thanks as always OP!!!
  18. Oct 12, 2018 at 11:14 PM
    #58
    MTNHABITOVERLAND
    I gotchu + REM :hattip: via PM
  19. Oct 12, 2018 at 11:19 PM
    #59
    MTNHABITOVERLAND
    ***Alright guys we’re nearing the first 15!! I’ll be DM’g the participants tomorrow for info so invoices can get to you ASAP. Please ensure POST #1 list has your correct order.***
    Cheers!
  20. Oct 13, 2018 at 5:21 AM
    #60
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    anyone do gears on a 4 cyl? The website says "*(requires carrier)". I searched around for a few hours but could not find any info on this, why is a carrier required?
    Also the website had this line...
    "When changing to A/M gears a new carrier is required: NC-T8S-3 or ARBRD121 at JustDifferentials.com."
    To what does the "A/M" refer?
    Sorry for the questions but this info isn't easy to find.
