Gears grind when i shift into third
Discussion in '1st Gen. Tacomas (1995-2004)' started by scrubs, Feb 17, 2014.
  1. Feb 17, 2014 at 3:40 PM
    scrubs
    scrubs [OP] Member
    south carolina
    SR5
    custom bumper, side rails, rhino lined
    I just recently bought a 98 tacoma sr5 and everytime i go to shift into 3rd it grinds if i dont let it wind back down. any advice on what ill have to get fixed?
  2. Feb 17, 2014 at 4:01 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Sure, but you won't like it.
    Tranny needs third gear synchromesh replaced.
    Try to go in 3rd real easy, see if that works.
    Third gear sychros seem to be the ones that go bad most often.
  3. Feb 17, 2014 at 4:06 PM
    lipster
    Northern MN
    License plate frame
    Did you buy this from a dealer, and how long ago?
    You may have recourse. You are talking major dollars to fix this.
    If no recourse, you can learn to drive it in a way that the gears don't grind, and it will go a long, long time. Forever, maybe.
  4. Feb 17, 2014 at 5:20 PM
    scrubs
    scrubs [OP] Member
    south carolina
    SR5
    ya when i go into it easy it doesnt grind at all. i guess ill just have to deal with it until i can get the money for it.
  5. Feb 17, 2014 at 5:36 PM
    scrubs
    scrubs [OP] Member
    south carolina
    SR5
    would if be cheaper to get a used transmission rather than try and get it fixed?
  6. Feb 17, 2014 at 5:39 PM
    lipster
    Northern MN
    License plate frame
    Prolly.
    Cheapest of all is to just shift slower into third and avoid the problem.
    Check out what the other poster suggested as well.
    Dunno why third synchro is so problematic, but it is on the 2005 and up 6 speeds as well.
    DAMHIK.
  7. Feb 17, 2014 at 5:44 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Third her is usually first to go as many noons cannot find third gear and wear it out. Or they don't dully engage it and wear out the syncro. Dunno about 2k. Talk to a tranny shop. Also, flush the trans and use decent fluids.
  8. Feb 18, 2014 at 12:15 AM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    You might be able to double clutch until you get it fixed!
