Gears
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rcfreak201, Nov 18, 2010.
  1. Nov 19, 2010 at 10:53 AM
    #41
    airdough
    airdough Member
    No, didn't recal my Odometer, but I have scanguage and can track the MPG that way. Plus I figure my tires have about a 7% greater circumference than stock, so multiply the miles on the tripmeter by 1.07 and divide by gallons it takes to fill = pretty accurate MPG calculation.
  2. Nov 19, 2010 at 11:02 AM
    #42
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Your stock tires were probably reading too many miles (too fast) anyways, so now you're accurate on your mileage. No reason to adjust for tire size.
  3. Nov 19, 2010 at 11:04 AM
    #43
    brandonlamb25
    brandonlamb25 Well-Known Member
    Georgia
    08 Crewcab Prerunner V6
    K&N Intake, Wet Okole Seat Covers, Ipod to Factory radio hookup kit, Black Low Pro Toolbox, Toytec Coilovers and 285/75r16 BFG MT's
    ok, great. so i guess i should go with the 4.30 over the 4.11 gears huh??
  4. Nov 19, 2010 at 11:15 AM
    #44
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Keep in mind that the chart is old. Their figuring was done on a 3 speed automatic transmission, 1:1 ratio. Now we have 5 speeds and over drive. 4th gear in an auto would b 1:1 and 5th would be either .70-.85 .
  5. Nov 19, 2010 at 11:16 AM
    #45
    airdough
    airdough Member
    Why do you say that, is the odometer/tripmeter off from the factory?
  6. Nov 19, 2010 at 11:21 AM
    #46
    PB65stang
    Patrick
    Kansas City
    Yes. My truck (Sport w/ 265/65/17 tires) was about 3-4 mph off at 70 mph. So it would say 70, and I was doing 67, or it would say 75, and I was doing 71-72 (per GPS). I get about 5% taller tires (265/70/17) and it's spot on now. Search on it, it's probably one of the most asked topics on the board.
  7. Nov 19, 2010 at 11:44 AM
    #47
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    hopefully soon i will share that awesomeness
  8. Nov 19, 2010 at 11:47 AM
    #48
    PLC721
    Patrick
    Chandler, Az
    noo i think i want 4.56's, but everytime i look at your truck 37's are more appealing than my 35's :drool:
  9. Nov 19, 2010 at 11:49 AM
    #49
    TBK224
    TBK224 ~THE LIGHT GUY~ Vendor
    Tim
    Phoenix, AZ
    BADASS TACO
    6" Pro Comp Stage One Lift Kit and 35" Toyo Open Country M/T's riding on 18" XD Addict Wheels
    I think I will be doing gears very soon. Either 4.56's or 4.88's. Hmm...??
  10. Nov 19, 2010 at 12:24 PM
    #50
    PLC721
    Patrick
    Chandler, Az
    he already pm'd me and we decided 4.56 is better for me as i go on the highway often
  11. Nov 19, 2010 at 12:29 PM
    #51
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    the speedo and odo are not directly connected. the speedos on this truck are off, but the odo is on. now that you have the 32s, the speedo is on, but your odo will read slightly slow. i've mapped it out w/ mine on 35s w/ the ultragauge and the mile markers on the interstate and my speedo is ~5-6 mph slow and the odo is off ~12-13 miles per every hundred driven (100 on odo=112-113 IRL).
  12. Nov 19, 2010 at 12:36 PM
    #52
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    This sounds almost exactly the difference of mine considering tire size. Comparing to GPS my mileage is 6.3% off and speedo is about 3 mph off and I'm running 285/75/16 so about half the difference from stock as what you are running.
  13. Nov 19, 2010 at 12:50 PM
    #53
    PB65stang
    Patrick
    Kansas City
    I'd be VERY interested in hearing more about this. I have no idea how a spedometer and an odometer could NOT be connected. Again, my only experience is older cars, but how could the truck know how many miles you've driven without knowing how fast you're going??
  14. Nov 19, 2010 at 12:51 PM
    #54
    The_Hodge
    SC
    from my understanding, they are pulling their sources from seperate places
    EDIT: corrected in posts 83/84
  15. Nov 19, 2010 at 12:55 PM
    #55
    PB65stang
    Patrick
    Kansas City
    If that's the case, yet another reason why I much prefer modding and working on cars without electronics. I'm not saying you're wrong (you're probably right), but it makes no sense to me why Toyota would do that. It would seem the most logical place to get miles driven information would be the speedomoter. But hell, what do I know?
    EDIT: I found the explanation about converting the digital signal to analog, and causing the difference. Makes logical sense, but it's still a dumb way of doing things. :D
  16. Nov 19, 2010 at 1:00 PM
    #56
    The_Hodge
    SC
    i just found that too...i knew there was something about the signal that was different to the devices...lol
  17. Nov 20, 2010 at 7:38 AM
    #57
    PLC721
    Patrick
    Chandler, Az
    well won't you get better milage than with a taller tire?
  18. Nov 21, 2010 at 12:51 AM
    #58
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    sounds like it might be a little pricey... does your guy offer any warranty.
    i was quoted 825 for mine so it seems like you paid a bit too much :notsure:
  19. Nov 21, 2010 at 12:56 AM
    #59
    Yoytoda
    Roland
    completely stock
    i have 2 lol... 4x4 :p
  20. Nov 21, 2010 at 1:22 AM
    #60
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    hit me up then!!!!!
