gears ???????????
Discussion in '1st Gen. Tacomas (1995-2004)' started by dzlguy, Oct 8, 2011.
  1. Oct 8, 2011 at 3:21 PM
    dzlguy
    dzlguy [OP] Member
    McGee
    Decatur,AL
    Tacoma 4X4
    K&N airfilter,3 IN BodyLift, ARE camper shell yakima rack ,magna flow exhaust
    hey guys i have a 98 toyota tacoma regular cab 4x4 5spd and im trying to find out what gears it has in it but i looked ob the vin and it has a ? mark were it should tell me any ideas?
  2. Oct 8, 2011 at 7:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    You can probably calculate it manually. Count the number of rear drive shaft revolutions it takes to rotate the rear wheel one full revolution. If it is slightly more than 4 drive shaft revs its a 4.10. If its almost 4.5 revs, its probably a 4.30. If its slightly less that 4, it'll be a 3.90. You get the idea.
  3. Oct 8, 2011 at 8:27 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Class.... Dismissed.
  4. Oct 8, 2011 at 8:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :confused:
  5. Oct 8, 2011 at 8:49 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    lol I was backin you up
  6. Oct 8, 2011 at 8:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The axle code for your rig can be found on the manufacture's sticker located on the driver's side door jamb as follows:
    First digit:
    • A = 7.5" ring gear
    • B = 8" ring gear
    Next two digits:
    • 01 = 3:42
    • 02 = 3:58
    • 03 = 4:10
    • 04 = 4:56
    • 05 = 3:15
    • 06 = 3:91
    • 07 = 4.30
    Last digit:
    • A = 2 Pinion, Open
    • B = 4 Pinion, Open
    • C = 2 Pinion OEM Limited Slip
  7. Oct 8, 2011 at 8:53 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I think the OP said there was a question mark where the diff code should be. Maybe I read that wrong. :eek:
    Thanks Man! :D
  8. Oct 8, 2011 at 9:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The gear code is not in the VIN. Its near the lower right of the sticker. It will be a 4 digit code, for example "B04A" .....
  9. Oct 8, 2011 at 9:23 PM
    Digiratus
    Roaming the PNW
    The RedHead
  10. Oct 9, 2011 at 12:55 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Shall we cast lots as to which it is??
    Im goin with B03a aka 4.10s :cool:
  11. Oct 9, 2011 at 7:53 AM
    dzlguy
    dzlguy [OP] Member
    McGee
    Decatur,AL
    Tacoma 4X4
    thanks for the info guys but were the gear code is it has a ? mark ill just do it by what digirauts said by turning the wheel
  12. Oct 9, 2011 at 8:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Can you post a pic? Are you looking in the right spot?
  13. Oct 9, 2011 at 10:48 AM
    dzlguy
    dzlguy [OP] Member
    McGee
    Decatur,AL
    Tacoma 4X4
    ill try to get one but yea lookin in right spot
  14. Oct 9, 2011 at 11:18 AM
    dzlguy
    dzlguy [OP] Member
    McGee
    Decatur,AL
    Tacoma 4X4
    yea were it says a/tm becide it has a ? mark like this A/TM ? /
