gears
Discussion in '1st Gen. Tacomas (1995-2004)' started by higherlux, Jan 27, 2009.
  1. Jan 27, 2009 at 8:19 AM
    higherlux
    higherlux [OP] Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    did 1st gens come with 3.?? gears???
  2. Jan 27, 2009 at 9:35 AM
    Racinkid13
    Racinkid13 Problem Child
    Kent,WA
    SR5 TRD debadged and beaten
    many
    4.10's i believe
  3. Jan 27, 2009 at 9:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They came with gears rangeing from 3:15's to 4:56's. Depends on the gear code on the door jamb.
  4. Jan 27, 2009 at 9:44 AM
    Dustin03
    Dustin03 The Cooler King
    Arizona
    Expeditionary vehicle in training.
    Old Man Emu 2.5" lift, brush guard (about to be changed), grey-wire mod, custom bed mounts for 4 jerrycans, custom survival box, maglite mount, KC Dayliters.
    You wouldn't happen to know what those codes are by any chance?
    Now I'm curious. :)
  5. Jan 27, 2009 at 9:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    http://www.tacomaterritory.com/wiki/index.php/Gear_Codes
    The axle code for your rig can be found on the manufacture's sticker located on the driver's side door jamb as follows:
    First digit:
    • A = 7.5" ring gear
    • B = 8" ring gear
    Next two digits:
    • 01 = 3:42
    • 02 = 3:58
    • 03 = 4:10
    • 04 = 4:56
    • 05 = 3:15
    • 06 = 3:91
    • 07 = 4.30
    Last digit:
    • A = 2 Pinion, Open
    • B = 4 Pinion, Open
    • C = 2 Pinion OEM Limited Slip
  6. Jan 27, 2009 at 9:52 AM
    Dustin03
    Arizona
    Chris, you're my hero.
  7. Jan 27, 2009 at 9:57 AM
    Racinkid13
    Kent,WA
    many
    Man Im slow these days, i was looking for that.
  8. Jan 27, 2009 at 10:01 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    my truck dosent have the door jam sticker i beleve the guy that had the truck before me took it out for some reason
    so i went by this...http://home.4x4wire.com/erik/diffs/#T100-Tundra
    and my drive shaft turned 3and a little bit over 1/2
    so im thinking 3.58????
  9. Jan 27, 2009 at 10:07 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    no but that is the most common type tho
  10. Jan 27, 2009 at 10:49 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    let me kno if i did anything wrong
    or if they offered them gears or ????
  11. Jan 27, 2009 at 11:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    3:58's were availible. Sounds like you did it right.
  12. Jan 27, 2009 at 11:34 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    damn looks like im getting new gears
    :D
