Gears
Discussion in '4 Cylinder' started by alteredillusions, Nov 1, 2009.
  1. Nov 1, 2009 at 5:51 PM
    alteredillusions
    alteredillusions [OP] Well-Known Member
    Wichita KS
    SR5 2.7 manual
    I know this has been talked about alot. But I'm a little confused on my gears. I have a 2006 SR5 2.7L 4x4 Acab What gears in my rear end do I have? I knoe the 2009 came with 4.10 do I have the same? Thank I'm new to the Taco world. just trded in my 2004 Ram 2wd ram for it. The wife wasn't to happy because i had just dropped almost 2k in aftermarket parts in my ram. Thanks for your help
  2. Nov 1, 2009 at 6:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You have 4:10 gears. :)
  3. Nov 1, 2009 at 6:02 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Yup same as my '07!
  4. Nov 1, 2009 at 6:05 PM
    alteredillusions
    Wichita KS
    SR5 2.7 manual
    Thanks guys so many posts talking about differnt gears i just wanted to make sure.
  5. Nov 1, 2009 at 6:14 PM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    I had the same question and was never able to find out. Do i also have 4:10 gears in my 2007 2.7L regular cab tacoma?
  6. Nov 1, 2009 at 6:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    4x4 or Prerunner? Or a 5 lug.
  7. Nov 2, 2009 at 6:40 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    PreRunner/4x4 = 4.10
    5 lug manual = 3.31
  8. Nov 2, 2009 at 12:50 PM
    MikeyD
    Sayreville NJ
    Its a 4x4 so I guess i have the 4:10 gears. Thanks for the help!
  9. Nov 2, 2009 at 3:02 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Good to know!:thumbsup:
  10. Nov 2, 2009 at 6:45 PM
    DrewNJ
    DrewNJ Member
    Doug
    Marlton, NJ
    How about in my 2.7 5-lug auto?
    Thanks
    Doug
  11. Nov 2, 2009 at 9:41 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    should be 3.58 in the auto, 3.31 in the manual
    and 3.73 in the v6 tacomas
  12. Nov 3, 2009 at 3:14 PM
    DrewNJ
    DrewNJ Member
    Doug
    Marlton, NJ
    Thanks man!
    It would be nice to find a 3.73 third memeber...:p
  13. Nov 3, 2009 at 6:11 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    what about 96 3RZ? is that 3.73?
  14. Nov 4, 2009 at 8:51 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    anyone running either 255/85/16 or 295/75/16 with their 4 banger and did a regear? what gear did you decide and whats the rpm at about 65 mph?
    the diff in height is less than half in and width is 1.5" (width i dont think matter when it comes to gears only height right?)
  15. Nov 4, 2009 at 8:59 AM
    afd23a
    The Dynamo of Dixie
    It sure would.....
  16. Nov 4, 2009 at 10:10 AM
    06dak
    Central Ohio
    Both matter, in that they both add weight. Width is probably more important than height since it's the main factor in adding rolling resistance, which you need to consider when you regear (even though you want to go down in RPMs, you still need them higher than normal so you can rotate the damn tires at freeway speeds!)
  17. Nov 4, 2009 at 10:16 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
  18. Nov 4, 2009 at 5:35 PM
    08pretaco
    az
    i thought for some reason people regear because of the tire diameter increase. doesnt having a wider tire just do that, give a wider tire? i realize it gives more resistance cause of surface area. i guess i just dont understand why someone would regear for a wider tire until i drove one that had a significant difference..
