geekhouse23's "LIFE'S WAITING TO BEGIN" Overland & Home build and all the Adventures in between!
Discussion in '2nd Gen. Builds (2005-2015)' started by geekhouse23, Nov 11, 2013.
  1. Apr 25, 2022 at 5:44 PM
    #6901
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    You probably have it embedded in all these pages however, I may have over looked it
    .. I'm switching from my aluminum bumper to DO steel bumper.(120ish lbs) my question is .. how do you like the 650# spring set up ? I'm currently on ome 887s but looking to go to fox or kings
    geekhouse23[OP] likes this.
  2. Apr 25, 2022 at 5:47 PM
    #6902
    geekhouse23
    geekhouse23 [OP] The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    This place (my build thread) is a shit show.
    I am happy with them. Not sure how well 650's would be with a steel bumper. You might have to run 700's. I didn't go that route because I didn't want to have a stiff front end
  3. Apr 25, 2022 at 6:30 PM
    #6903
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Very true. My neighbors on either side are retired and I'm in my 40s but we get on well.
  4. Apr 25, 2022 at 8:08 PM
    #6904
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I'm on 6112s with 650lb springs. The ride is nice and smooth. I have a Coastal Offroad HC Front bumper with full hoops and an Apex 12k Winch currently. ATM I don't have my sliders or skids on yet.
    Jeffvt0508[QUOTED] likes this.
  5. Apr 26, 2022 at 11:57 AM
    #6905
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    full steel or full hybrid? I have a hybrid Pelfrey with Smittybilt X20 winch with synthetic line and steel skids, and I like the 650# over 700s. If you are doing a full steel with or without hoops, Id suggest 700
  6. Apr 26, 2022 at 12:12 PM
    #6906
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    find a 650# spring that's longer so you get a cushy ride but not so much preload is also an option.
    Slashaar likes this.
  7. Apr 26, 2022 at 3:46 PM
    #6907
    Jeffvt0508
    Jeff
    Anderson, SC
    It's full hoop steel but I asked demello and they said it weighs 120 lbs.. but right now I have aluminum bumper that's line-xed
  8. Apr 26, 2022 at 3:49 PM
    #6908
    fatfurious2
    David
    Ashburn, VA
    Hmm, I was under the impression that my steel hybrid bumper was 110lbs.. Aluminum must be 60
  9. Apr 26, 2022 at 3:49 PM
    #6909
    geekhouse23
    Like Conner suggested, I would buy the longer 650lb coils and then adjust the preload.
    Saves time, effort and money than bouncing between springs and will get your dampening dialed.
  10. Apr 26, 2022 at 3:50 PM
    #6910
    geekhouse23
    I was able to install my aluminum Pelfrey (winchless) on my own. Mind you this was pre-chapter 7 so I didn't have to lift all the weight of the customers they screwed over
    Gunshot-6A and Slashaar like this.
  11. Apr 26, 2022 at 3:50 PM
    #6911
    Jeffvt0508
    Jeff
    Anderson, SC
    I was looking at fox or king.. using the 14 in coil spring with either
  12. Apr 26, 2022 at 3:51 PM
    #6912
    Slashaar
    Josh
    Kansas City, MO
    My coastal full plate bumper was 104lbs before I welded on it.
    fatfurious2[QUOTED] likes this.
  13. Apr 26, 2022 at 3:52 PM
    #6913
    geekhouse23
    Everyone has their preference. Fox was not an option due to the salt they put down. They're known for rusting pretty badly
  14. Apr 26, 2022 at 3:54 PM
    #6914
    fatfurious2
    David
    Ashburn, VA
    me too, ~2016. I was able to install mine on my own, but I had more muscles than I do now :rofl: aka, I got fatter.
  15. Apr 26, 2022 at 3:54 PM
    #6915
    Jeffvt0508
    Jeff
    Anderson, SC
    I'm 23 in hub to fender in front and 24.5 hub to fender in rear.. so hopefully with everything I'll stay at same height..I'm waiting to get the bumper before i touch shocks... I feel like a noob again with all this... I wasn't planning on changing armor until I found out about the company I have everything with
    geekhouse23[OP] and Slashaar like this.
  16. Apr 26, 2022 at 3:56 PM
    #6916
    Jeffvt0508
    Jeff
    Anderson, SC
    I didn't know that rusted... interesting...
  17. Apr 26, 2022 at 3:56 PM
    #6917
    geekhouse23
    Like I said, coilovers can get your height dialed in as long as you don't crank up the preload.
  18. Apr 26, 2022 at 3:57 PM
    #6918
    geekhouse23
    Fox was on my list until I asked around locally.
    Icon top hats blow apart (another local)
    It was between Kings and ADS.
  19. Apr 26, 2022 at 3:59 PM
    #6919
    Jeffvt0508
    Jeff
    Anderson, SC
    I was going icons until people around here were talking that they just leaked more and were equal to ome as a basic coilover
  20. Apr 26, 2022 at 4:01 PM
    #6920
    Jeffvt0508
    Jeff
    Anderson, SC
    I have S0S concepts. So I'm looking to slowly convert to better reputable companies and so I can Actually winch...seem sos aluminum fail while winching
