geekhouse23's "LIFE'S WAITING TO BEGIN" Overland & Home build and all the Adventures in between!
Discussion in '2nd Gen. Builds (2005-2015)' started by geekhouse23, Nov 11, 2013.
  1. Jan 3, 2016 at 12:15 PM
    #1261
    geekhouse23
    geekhouse23 [OP] The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    $125 without a calculator to get the exact penny amount
    2ndGenJonny[QUOTED] and Acerwin like this.
  2. Jan 3, 2016 at 12:15 PM
    #1262
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Not to bad at all. That's what I'm wanting to spend
  3. Jan 3, 2016 at 12:17 PM
    #1263
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Ill give you $150 :spy:
    GARSHA91 and TacoFMS like this.
  4. Jan 3, 2016 at 12:19 PM
    #1264
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    You buying it for me how sweet buddy
  5. Jan 3, 2016 at 12:19 PM
    #1265
    geekhouse23
    That's including shelling out the extra $30 more for the same regulator as Wheeler's. Without that, $95 and change
    Hmmmm.......
  6. Jan 3, 2016 at 12:19 PM
    #1266
    geekhouse23
    :rofl:
  7. Jan 3, 2016 at 12:22 PM
    #1267
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    I'll go $151. :D
  8. Jan 3, 2016 at 12:22 PM
    #1268
    geekhouse23
    I will also have about another $25 to invest in a mounting system I designed in my head last night but still, not bad for $150 for a 20lb CO2 setup
    2ndGenJonny likes this.
  9. Jan 3, 2016 at 12:23 PM
    #1269
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    I'll go. Taco convoy?
  10. Jan 3, 2016 at 12:25 PM
    #1270
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    He's already buying it for me :D
    ChandlerDOOM likes this.
  11. Jan 3, 2016 at 12:26 PM
    #1271
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Yes in the form of a trade for stickers/patches
  12. Jan 3, 2016 at 12:28 PM
    #1272
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    :yes:
  13. Jan 3, 2016 at 12:33 PM
    #1273
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    I found a bottle but $100
  14. Jan 3, 2016 at 12:33 PM
    #1274
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    That's my damn problem.
    geekhouse23[OP] likes this.
  15. Jan 3, 2016 at 1:03 PM
    #1275
    geekhouse23
    CO2 tank HOW-TO:
    1) Find a CO2 tank on craigslist for under $100; I scored this 20 lb. tank cheap and with a handle luckily :wink:
    Meet the man (or woman) and claim the precious as your own (pay him or her their money)
    2) Take a trip to Harbor Freight Tools and spend $10 :eek: (yes $10)
    Purchase the following: **Depending if you have an ARB hose/compressor, you will not have to purchase a hose. I bought one to keep attached while the bottle is mounted in the truck at all times (fast and compact); I won't have to go digging for my ARB hose. But it will work.**
    **Also not included is an inflator. I personally have a PowerTank that is already in my arsenal. Harbor Freight SHOULD have them for under $10**
    3) Purchase a regulator. This can be the next expensive item after the tank or most expensive depending how much of a deal you got. Here is the one I purchased:
    http://trdparts4u.toyotaofdallas.com/scripts/prodList.asp
    **This is available at wheeler's offroad for $55 (not including shipping) they are still a few months out from having these available and I spent the extra $30 to have it sooner. Just a note**
    ASSEMBLY:
    Lay out all your parts and grab two open ended present wrenches from your tool box.
    Install the female brass nipple on one end of the hose using your teflon tape on the male threading. And install the female quick connect using teflon tape on the other end of the hosing.
    **You DO NOT have to use teflon tape here. The fittings on the regulator came with teflon tape on them so I decided to just go ahead and do it.**
    Here is what it should look like completely assembled:
    FINAL ASSEMBLY:
    Take your regulator and thread it onto the CO2 valve of the tank **DO NOT USE TEFLON TAPE** Tighten everything with a crescent wrench and be gentle on the brass..you can mangle it. Here is how everything looks when it is buttoned up:
    INFLATORS:
    Here is what I have for inflating the tires (didn't purchase another inflator as this was already in my arsenal)
    You can go with something a bit cheaper such as this: What does this all cost?
    TOTAL I spent not including the inflator:
    Tank - $30 after about $50 of parts I had laying around the garage not being used
    Regulator - $81.90
    Fittings - $4.59
    Hose - $3.99
    Teflon tape - $0.79
    GRAND TOTAL: $121.27
    MOUNT:
    Originally, I thought that I could use quick fists for extra savings, but they were too small..back to the drawing board :pout:
    For the mount, I went with the 20 LB. mount from Wheeler's off road found
    Depending on the size of the tank, you can get one VERY cheap for under $50 with shipping. For mine, I paid $64.50 SHIPPED.
    The bracket:
    Tank in the bracket:
    MOUNTING THE BRACKET IN THE BED:
    Flat steel
    Nuts and bolts
    Mounted to the bed rail with appropriate tslot nuts and bolts/washers etc
    Finished product!
    UPGRADED HOSING: http://www.amazon.com/gp/product/B004HQGDYK?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
    UPDATED AND FINAL TOTAL: $203.94
    Let me know if you guys have any questions!
  16. Jan 3, 2016 at 1:07 PM
    #1276
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Done this a few weeks earlier and could've been the build thread of the year ;)
  17. Jan 3, 2016 at 1:12 PM
    #1277
    geekhouse23
    Never will win that in the entirety of Caitlyn's life. Ever.
    Acerwin[QUOTED] likes this.
  18. Jan 3, 2016 at 1:20 PM
    #1278
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    No worries mine either
  19. Jan 3, 2016 at 1:21 PM
    #1279
    geekhouse23
    And you have Kings..
  20. Jan 3, 2016 at 1:22 PM
    #1280
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    But not building it fast enough...
