Gen 1 6-Cyl Valve Adjustment?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Flash1034, Dec 7, 2010.
  1. Dec 7, 2010 at 1:42 PM
    Flash1034
    Flash1034 [OP] Well-Known Member
    Southern California
    2003 SR5 TRD 4x4 Extracab 3.4 liter
    None
    Is it really necessary to adjust the valves on these trucks? (2003 3.4 liter) If so, is it a big job?
    Thanks,
    Flash
  2. Dec 9, 2010 at 8:51 PM
    Corleykj
    Corleykj Member
    Kyle
    Casper, WY
    Double Cab 4x4 trd
    Bilstein 5100's on 1 1/4" (middle), Rear AAL's
    I am willing to tackle adjusting the valves. I haven't done it on an engine, but have done it on TONS of small gas engines since I teach SGE.
    Any tips to make it go smoother?
    Certain style feeler gauges or any other tools that make it fast?
    Thanks in advance.
  3. Dec 9, 2010 at 10:31 PM
    Flash1034
    Southern California
    None
    I wonder if its really necessary on the 6 cyls. Are the valves out of spec that much?
    Flash
  4. Dec 9, 2010 at 10:36 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    why would one need to adjust valve's?
  5. Dec 9, 2010 at 10:46 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    If they are loud, then yea, but otherwise no. You really only have to regularly adjust valve clearance on cars that are designed to be easy to adjust. Ones where you just remove the valve cover, loosen a nut, use a feeler gauge, tighten it, and put the valve cover back on. If it's a long difficult thing to do, odds are it's not something you ever need to do regularly. Probably only when you rebuild the engine.
  6. Dec 10, 2010 at 9:21 AM
    Flash1034
    Southern California
    None
    Doesnt the service manual say the valves need adjustment every 80k?
    Flash
  7. Dec 10, 2010 at 9:23 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Its a shim over bucket valve train I think. So you cant really adjust it as the cam lobe presses directly on the shim/bucket which are over the valves, so theres no rocker arms. Thats what I have read.
  8. Dec 10, 2010 at 9:33 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    It IS shim and bucket design so you will have to first measure the valves, see how far out they are and order the correct size shims to correct the problem. You will have to remove the valves to do this so its a pretty big job on this motor. Honestly if you're under 200k miles I wouldn't worry unless its making a lot of noise.
  9. Dec 10, 2010 at 9:36 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    ^^Those = This VV
  10. Dec 10, 2010 at 9:45 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    ^^ :D We are so smart when we put our heads together! :eek::eek:
  11. Dec 10, 2010 at 9:47 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
