Gen 1 P0456 code (emissions systems small leak detected)
Discussion in 'Technical Chat' started by taco57, Mar 30, 2018.
  1. Mar 30, 2018 at 8:37 AM
    taco57
    taco57 [OP] Well-Known Member
    Jeff
    Columbus Ohio
    2003 Tacoma SR5 4X4 2.7 5 speed
    All,
    2003 ex cab, 226K miles. I get the P0456 code from time to time and do notice a fuel smell around the gas tank - charcoal canister area when I park in my garage. It is more prominent when I fill the tank.
    What is the most likely candidate for the leak? The charcoal canister itself? Hoses? Is the only way to service or repair is to remove the bed? Can't see anything but know it is there because of the code and smell.
    Thanks!
  2. Jul 6, 2018 at 9:10 AM
    taco57
    Jeff
    Columbus Ohio
    I guess I'll reply to myself. LOL
    Had the smoke test done and it ended up being the gas cap. I did not suspect that was the issue because I had a brand new aftermarket and the original with no change so I figured it had to be something else. Wrong. It was the gas cap, both were bad. Bit the bullet and bought Toyota OEM.
  3. Jul 24, 2018 at 3:38 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    I learned my lesson and now buy only OEM gas caps. Gently wipe the fuel tank filler tube, gas cap rubber O-ring with a clean windshield towel every time you get gas. You'll be surprised by how much dirt comes off. The cap will last twice as long. You can buy just a replacement O-ring, but I've never bothered trying to change one.
  4. Jul 25, 2018 at 8:30 AM
    taco57
    Jeff
    Columbus Ohio
    Well, here I am today. New OEM gas cap and still have the problem. 0456 small leak detected. Smoke test supposedly indicated leak in the filler tube somewhere. Have to drop the tank or remove the bed to fix.
    Anybody seen this before and how hard is it really to replace the filler tube assembly with the bed on?
  5. Aug 4, 2018 at 4:13 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    Still sounds like the gas cap. Even a new one can leak, maybe dirty from the manufacturing process, or microscopic dirt/grit on the fill tube inlet? Wipe the cap and fill inlet good, clear the code, try it again. Amazing how dirty they get.
  6. Aug 9, 2018 at 3:10 PM
    taco57
    Jeff
    Columbus Ohio
    Yeah, I tried that on several occasions. I am going to get in there and clean the filler tube and everything else I can get to to see if I can finally actually visually see a moist area. The fumes are strong enough that I would think I would be able to see something. Luckily for me I have a scan gauge that I can simply reset the light on the fly each time. But it is getting very annoying, plus the deer wife complains of the gas smell in the garage
